eddymcclements
| posted on 18/4/06 at 01:29 PM |
Dry sump
Following on from my sump/tarmac interface (see
http://www.locostbuilders.co.uk/viewthread.php?tid=42558) and the ensuing thoughts
about dry sumping (see also
http://www.locostbuilders.co.uk/viewthread.php?tid=38241&page=2)
I've made some more progress.
I already bought a Westfield dry sump tank off eBay
and have now bought a Pinto oil pump and dismantled it for the gears. I'm going to make a new housing to accept the gears and fit a longer shaft
and bearings plus oil seal at the front, and bore and tap the rear to take fittings for the scavenge hoses.
Gears plus 3" billet I had lying around
  Pinto oil pump gears
Cut off a length of billet, parted and faced, drilled and tapped for the bolts holding the pump body together (the pump body is in two parts in this
picture, but you can't see the join)
  Dry sump pump parts 1
The same parts, but separated
  Dry sump pump parts 2
Next steps are to machine out the middle, press out the short shaft from the 4-node impeller and find some 1/2" silver steel rod to make a longer
shaft, a couple of ball races and a 1/2" oil seal.
Eddy
liam.mccaffrey
| posted on 18/4/06 at 04:25 PM |
i like the cut of your jib
what lathe have you got?
Build Blog
Build Photo Album
MikeR
| posted on 18/4/06 at 04:37 PM |
is it really that simple, i thought the pump had to be self priming for when it sucked air on corners / accel / braking
eddymcclements
| posted on 18/4/06 at 04:38 PM |
Ex-school 5" Boxford. Would have liked an AUD (gearbox for screwcutting and power crossfeed) or BUD (power-crossfeed) but ended up with a CUD
(change gears for screwcutting, 3mm pitch leadscrew and backgear, but no power crossfeed). Takes a little bit longer to set up , but you can achieve
the same results in the end. This pump project is immensely satisfying.
Eddy
SeaBass
| posted on 18/4/06 at 04:46 PM |
Is that 3" Aluminium round bar your using??
eddymcclements
| posted on 18/4/06 at 04:47 PM |
MikeR - the truthful answer is...I don't know. The pump will be mounted very low down, probably level with the sump, so if the pump has trouble
priming then the level of oil will soon rise to be the same as the scavenge pipe and this should then automatically prime the pump.
I've been looking at the Pace Products web site their Slim Jim and Compact C pumps are very similar internally - I can't see any reason
why they would prime and mine wouldn't. Time will tell.
Eddy
eddymcclements
| posted on 18/4/06 at 04:49 PM |
SeaBass - yes, I bought a lump of it a while back (I was going to make some TBs before motorcycle ones became widely available). I think it's
6082 or 6061 and machines really nicely.
Eddy
MikeR
| posted on 18/4/06 at 04:50 PM |
good luck and make sure you keep us posted. I'd always imagined dry sump pumps contained some magical black arts.
Is there not some scope here to do a two stage pump. One low down to collect the oil and one somewhere else to pump it into the engine?
eddymcclements
| posted on 18/4/06 at 05:02 PM |
I'm going to plumb the d/s tank back to the stock oil pump and allow that to feed the engine. Jon Ison drew a sketch in that Dry Sump thread and
I'm going to follow that method. Then when I've run a set of mains or seized the crank I'm going to sue Jon for a new engine.
Basically it'll be a single scavenge, inbuilt pump system. My guess is that because the Pinto uses a spray bar to oil the cam it has a fairly
large oil pump as standard, which means it ought to keep up with the demands of my 4AGE pump, especially if driven at full crank speed. I can always
extend the housing with a second stage and another set of gears - this oil pump cost 99p off eBay.
Eddy
MikeR
| posted on 23/4/06 at 09:04 AM |
Ah, think that will work then. I thought you where saying first of all that you would only have one pump in the whole system.
Jeffers_S13
| posted on 29/6/07 at 10:23 AM |
Any news/updates on this ?
obr_technology
| posted on 2/1/14 at 02:06 PM |
I was wondering if you completed this pump? The idea seems very good and I'm doing something similar myself but using a 2nd hand dry sump pump
from a single seater.
I hope you got it running!
Olly
clairetoo
| posted on 2/1/14 at 05:26 PM |
Since he was last on-line on 26/5/08 I'm thinking you aint gonna get an instant reply........
I read a lot on making a dry sump system a few years ago , the main thing I remember is that the scavenge pump has to at least double the capacity of
the pressure pump as it will spend a lot of time pumping an oil / air mixture , which then needs to be sorted in the tank .
Its cuz I is blond , innit
Claire xx
Will weld for food......
obr_technology
| posted on 2/1/14 at 07:38 PM |
Yeah think you might be right there, not really expecting a reply.
Yes I've read similar about scavenge stage size and having now stripped the dry sump pump I have the scavenge is just two of the same as the
pressure stage.
Olly
