Chazzy
posted on 1/6/06 at 06:25 PM |
In line thermostat completed!
thought i'd share with you all my latest "upgrade" After a bit of thinking and research i ended up using a BMW in line stat. biggest
prob was finding a 32mm T piece, ended up at an aquarium suppliers!
fitted it today, halfords still do flexi hose :-) It all works as well,phew! One query, the temp gauge on occassions goes from 80 to 110 in about a
minute then back again in about 10 secs, the fan doesn't alweays kick in so the water isn't that hot, could it be an air bubble by the
sensor? it did this a year ago then stopped, i'm hoping it will settle down.
Chas
Danozeman
posted on 1/6/06 at 06:31 PM |
Sounds good. Your problem sounds like an air lock somewhere.
Dan
posted on 1/6/06 at 07:44 PM |
The temperature fluctuations sounds like a by-pass issue.
Source of 32 mm tees = Rover 75 1.8 (other 75s engine types too and I am pretty sure and late MGTF ) -- also handy 32 joiners which can be found on
just about just about any late 90s Rover.
Just before the axe fell Rover switched to a variation on the BMW inline thermostat called PRT, that opens on presure as well as temperature, this
was a very effective tweek.
