mad dad
| posted on 11/10/06 at 08:47 PM |
which engine oil and how much
about to do engine oil and filter change for first time (since i've bought car - for piece of mind) on a 1999 fireblade engine wondered what was
best oil - fully synthetic or semi and been told to put in 4 litres. interested to hear what everyones thoughts/experiences are, Thanks
INDY BIRD
| posted on 11/10/06 at 08:56 PM |
If you are suffolk based best person to ask is Andy at AB performance located in Bury St Edmunds.
Good bloke tel no 01449 736633
He knows everything about blade engines as he races them and prepares other race cars.
Sean
bigrich
| posted on 11/10/06 at 09:28 PM |
i personally would use a good quality motorcycle semi synthetic and always a genuine filter. some say fully synthetic can cause clutch slipping
problems. as for level i just used to fill mine to the top of the sight glass(very slightly over full)
zetec7
| posted on 11/10/06 at 11:31 PM |
My Kawasaki 1000 has alway had Motul, since the bike was new. No noticable wear on the clutch, no slipping, no consumption in over 100,000 kms!
'Spensive, tho...
mad dad
| posted on 12/10/06 at 07:23 AM |
Thanks for that will give Andy a call there's a few other things i can ask him as well!!!........cheers
Catpuss
| posted on 12/10/06 at 07:30 AM |
IIRC API-SG, semi or fully synthetic oil.
For a blade engine I would double check but probably semi synth. Full synth on an engine that is normally semi can result in some oil consuption, but
thats about it.
I've always used semi on bike 4-stroke engines even my old '88 GSX600F & GS500 I used to have.
I'd go for something like the Castrol GPS(?). I've tried the Halfords own brand which is just a rebadged and is good enough. The only
problem with this stuff is that its supplied in some odd size where you end up with half a litre or so spare.
trifield
| posted on 12/10/06 at 09:36 AM |
I use Motul semi synth and all my biker mates use it in their blades.
If you are ever out on a run and need to top up the oil for whatever reason, you'll find it difficult to buy fully synth from a normal petrol
station but they usually have semi synth.
mad dad
| posted on 13/10/06 at 01:08 PM |
Thanks everyone spoke to Andy at AB really helpful so Castrol GTS it is will get some at weekend and a new filter.....
