Jos Fury
| posted on 24/10/06 at 11:06 AM |
Airbox for Pipercross PX500
Dear forum members,
My name is Jos and I live in the Netherlands. I am driving a Fury.
The engine is a 4age with TB's.
I am using the Pipercross PX 500 with base plate. I am looking for an airbox though. Unfortunately the PX600 solution incl. airbox does not fit due to
the limited space. I use the C503D type PX 500
( for dimensions ).
I ran the search on the forum here but no result for my "problem". I read a lot though about airboxes here and it was really interesting
Best regards
Jos
givemethebighammer
| posted on 25/11/06 at 10:24 PM |
I made an airbox to fit the pipercross baseplate. Just find and old foam filter (on ebay etc), cut the filter off and remove the old adhesive. You can
then make a box to fit to it from whatever you want (mine is aluminium)
http://www.locostbuilders.co.uk/viewthread.php?tid=54014&page=2
Mine is only for noise reduction on track days, I normally just have the foam sausage filter fitted.
Jos Fury
| posted on 30/11/06 at 08:20 AM |
Dear give me the big hammer,
Thank you. Had not thought about that ! Thanks very much. You box looks okay. Well done. Yes I want to reduce noise ( now and than ) And quickly
change filter if possible.
Since I am using Tb's in combination with injection no need to change setup for fuel / ignition all the time too.
Thanks again for posting your solution.
Best Regards
Jos
[Edited on 30/11/06 by Jos Fury]
