Doug68
posted on 17/3/07 at 11:09 PM |
3D Frame model.
I've published a 3D model of the frame I'm starting to build here thought some of you
might find it interesting.
geoffreyh
posted on 18/3/07 at 12:40 AM |
Nice work
My first remark would be: try to find a solution to your side construction because otherwise it will be a real pain to get in the car ;-)
Geoff
Doug68
posted on 18/3/07 at 02:40 AM |
Previously I've built a built a full size MDF mock up of the driver 'tub' to test this and the situation will be OK.
External to the frame you see here are aluminium 'boxes' that stiffen the side frames in torsion some more.
locostv8
posted on 18/3/07 at 07:37 AM |
What software did you use?
http://wrangler.rutgers.edu/gallery2/v/7slotgrille/hssss/
Doug68
posted on 18/3/07 at 08:48 AM |
I modeled this in SolidEdge and used their web publish functionality to show it on the web.
