graememk
posted on 24/4/07 at 02:50 PM |
thred lock
now i'm sva'd i'm going to strip down all 4 corners check tighted and thred lock all my nuts and bolts just for my own peice of
mind, i sent the shop lad out to get thred lock today and he came back with this thing that looks like blue pritstick, i normally use one that comes
in a tube like glue, is the blue pritstick stuff ok ?
[Edited on 24/4/07 by graememk]
chockymonster
posted on 24/4/07 at 02:54 PM |
It's fine.
I've used the red and the blue one throughout the build with no issues.
posted on 24/4/07 at 02:59 PM |
It should be fine. If you want to get all fancy you can check what grade it is (if it's stated). Most threadlocks get compared (IIRC) to 3Ms
codes...
Personally I never trust the codes and do a trial run with a spare bolt and a non-nylock nut to see how strong it is....
Mr Whippy
posted on 24/4/07 at 03:11 PM |
I would just use the nylock's if there new they will never come loose, so far as I have ever seen.
graememk
posted on 24/4/07 at 03:14 PM |
i've used nylocks as well, suppose i'm just panicing to much
balidey
posted on 24/4/07 at 03:28 PM |
I've not used the 'stick' ones yet, but they have been developed so we can put them in our pockets without our nuts getting covered
(acording to Loctite)
Bluemoon
posted on 24/4/07 at 03:53 PM |
You could put a small dab of paint across the blot/nut (or cheap nail varnish as this has a brush as well). You can check to see if anything has
moved..
Dan
posted on 24/4/07 at 04:26 PM |
Yup I'd recommend doing that as well, especially if you don't routinely check your nuts....
