New Topic New Reply
Author: Subject: Wheel spacers.. recommended?
LoMoss
posted on 23/5/07 at 10:39 PM Reply With Quote
I have acquired a set of Ford 15" 6J with 195 50 alloy wheels. the offset is approx 40mm and therfore need wheel spacers. Been looking at HnR spacers. Is this a good thing to do to a locost. Or can somebody recommend a source of 15" multi spoke alloys that would fit.
Opinions appreciated.
Hall
chockymonster
posted on 23/5/07 at 11:14 PM Reply With Quote
What offset do you need?
daviep
posted on 24/5/07 at 07:23 AM Reply With Quote
I've got a pair of 1" spacers you can have for a £10 I'll have a look and see if I've got long studs as well.
I'm in Kirkcaldy today/tonight but I'm going offshore tomorrow.
Cheers Davie
russbost
posted on 24/5/07 at 07:39 AM Reply With Quote
If you're going to use spacers the one-piece type with studs already mounted are much safer.
LoMoss
posted on 24/5/07 at 07:52 AM Reply With Quote
Require a pair of H & R DRM 70mm wheel spacers. gives 35mm per side and a clearance of 8mm. Is this too close for comfort?
RazMan
posted on 24/5/07 at 08:00 AM Reply With Quote
If you have to uses spacers make sure they are the hubcentric variety or you will have all sorts of wobbly problems.
Raz
COREdevelopments
posted on 24/5/07 at 01:05 PM Reply With Quote
i plan on using hubcentric wheel spacers approx 55mm, they are expensive but i dont fancy useing those dodgy cast ones. and the wheel will sit properly on the alloy spacer.
atb
rob
New Topic New Reply
