wheezy
posted on 24/5/07 at 06:29 PM |
Bullet cam supply
Having just bought the 4Kam package I am looking at connecting it to the car 12v supply to do away with the separate 12v battery pack.
My question is do you need a 12v regulator or can you fit directly into the car electrics.
Some of the bullet cam suppliers say yes some say no!!!
Any sugestions
Dave
posted on 24/5/07 at 06:34 PM |
i would recommend you use a regulator, car voltage can vary quite a lot and im sure its best to protect delicate equiptment. I ran mine on batteries
specifically to keep it seperate from my bec regulator!
jos
posted on 24/5/07 at 06:35 PM |
i was thinking exactly the same when i was in stainsburies paying out for 16AAA batteries
I'll be interested to see the responses
flak monkey
posted on 24/5/07 at 06:36 PM |
Depends what the input voltage range for the camera is, if its say 10-16V then you will be fine. But if its 11.5-12.5volts then you will need a
regulator.
Voltage regs are available off the shelf, they basically look like a big transistor and cost a couple of quid.
http://www.maplin.co.uk/Module.aspx?ModuleNo=7939&&source=14&doy=24m5
Plonk it on a heatsink in a box with a switch on, and you have yourself a 12v regulated output.
I did something similar with a 12v and 5v ouput on for my cam and recorder, works a treat.
[Edited on 24/5/07 by flak monkey]
Sera
http://www.motosera.com
russbost
posted on 24/5/07 at 06:43 PM |
You can buy a complete unit with switchable voltages for about £7 - got mine at a local accessory shop - for the price not worth taking the risk IMO
wheezy
posted on 24/5/07 at 06:44 PM |
Having looked at the 4Kam website there 12v pick off is just 2 wires and a plug which they recommend for cars and bikes.
Link
Maybe I should er on the side of caution and fit a regulator. I dont want to fry the cam having only just got it
Dave
gingerprince
posted on 24/5/07 at 06:59 PM |
Dave
They sell a wire implying you can wire it straight up to your car, which implies it has quite a wide operating voltage.
Also since they imply it's okay, then if it does go pop you've got a claim for a replacement surely.
wheezy
posted on 24/5/07 at 07:05 PM |
I will e-mail them tommorrow and find out what the implications are.
Dave
bigrich
posted on 24/5/07 at 08:32 PM |
i got the lead and a y harness to supply both my cameras when i ordered my kit
wheezy
posted on 31/5/07 at 02:23 PM |
Just got an e-mail back from 4Kam and they say that I can fit a regulator if I want but the camera can cope with an un regulated supply.
Problem solved.
