dave r
| posted on 7/1/08 at 06:35 PM |
air filter material
anyone know where you can but the pipercross type of filter foam on a roll ??
i have half built an airbox for my bike carbs, and need a flat bit
i have some filter material that we use at work, bu it catches fire rather easily
jacko
| posted on 7/1/08 at 06:39 PM |
Hi have a look in aquatic shops for pump filters they may have something !!!!!!!
| posted on 7/1/08 at 07:22 PM |
I hate to say this but it might be best buying a proper panel to cut down. A bad air filter can either let through abrasive particles or rob you of
lots of lovely brake horse power!!!
paulf
| posted on 7/1/08 at 09:54 PM |
Hi Dave , i looked for some of this my self to make a filter and found that fish keeping shops that specialise in Koi had some sheets available in 3
grades but not in large enough sizes for what i needed,
I also found a firm in Wellingboro that supplies foam of all types and called in some time ago , they hadnt got any airfilter foam of the correct
type as an off cut but would supply some when available what you need is polyurethane type.
Paul.
balidey
| posted on 7/1/08 at 11:03 PM |
I know that ITG make filters to order, so try contacting them
skodaman
| posted on 8/1/08 at 02:14 AM |
Sell it at work. £2.50 for a piece approx 18x10". £5.00 for a piece double that size. Comes in a choice of three difference grades. Yes
it's for pond filters. If ur stuck i'll send u some.
Skodaman
