New Topic New Reply
Author: Subject: Council Garage - Lighting - Charging
Guinness
posted on 20/5/08 at 05:03 PM Reply With Quote
A mate of mine keeps his Caterham in a "Council" type garage that is part of a block of garages round the corner from his flat.
Trouble is the battery keeps going flat between drives and there is no mains electricity.
So I thought about mounting a trickle charger solar panel on panel above the door (luckily it faces south) and extending the wire inside to the car.
So far so simple. But I was wondering if the trickle charger could charge a "spare" battery as well. From this I'd run a switch and a couple of low energy 12v flourescent tubes, so you could see whats in the garage at night!
Anyone know how to wire this up so that 1 trickle charger keeps both batteries charged up, but that having the lights on only runs the spare battery down, leaving the one on the car ready to go?
Mike
posted on 20/5/08 at 05:06 PM Reply With Quote
They don't give a lot of charging current - enough to keep a well-charged battery topped up, but little more.
I don't think they'd charge a battery up from a discharged state...
joneh
posted on 20/5/08 at 05:38 PM Reply With Quote
http://www.maplin.co.uk/Search.aspx?criteria=solar&source=15&SD =Y
Won't this do the trick? First result.
posted on 20/5/08 at 06:17 PM Reply With Quote
That's the one I've got - bought in Maplins on special offer ages ago.
omega 24 v6
posted on 20/5/08 at 06:43 PM Reply With Quote
we use them at work as a back up charging system for on board trailer batteries. As already said they will struggle to do the job mate. 2 off around 400mmX800mm certainly are not enough to charge a well flat battery. Sorry
posted on 20/5/08 at 06:51 PM Reply With Quote
However, they may well help to stop a fully charged and healthy battery from losing charge over time - which, in all fairness, is all they claim it will do.
Bigheppy
posted on 20/5/08 at 06:56 PM Reply With Quote
I bought a generator cost £39 but I have recently seen em at car boot sales /markets for £35. This would enable you to use tools as well as lights. The solar charger would then be perfect to keep your battery charged.
owelly
posted on 20/5/08 at 07:30 PM Reply With Quote
I know of dozens of folks who used these solar panels to keep the battery topped up on boats (there was a BOGOF offer in some boaty magazine). Consequently, there were dozens of these things littering the skip outside the boatyard. You need to keep the battery topped up for when the bilge pump wants to play.
I tried one from Maplins a few years ago and it failed to overcome the current drawn from the digital clock on my car......
http://www.ppcmag.co.uk
posted on 20/5/08 at 07:39 PM Reply With Quote
I use an inverter to power a couple of 5 foot lights from a12v battery which seem to last fairly well between charges. Jump pack for starting the car if needed. Perhaps he should use the car more often or get the battery and charging system checked? Painting the walls and fitting plaster board sheets help with the lighting
posted on 20/5/08 at 08:14 PM Reply With Quote
I must admit that mine has been on top of a shelf in my garage for the past 2 years, so I'd best keep quiet...
[Edited on 20/5/08 by David Jenkins]
posted on 20/5/08 at 08:17 PM Reply With Quote
LED lighting is the most energy efficient by a very large margin --- but you don't get much light.
omega 24 v6
posted on 20/5/08 at 08:57 PM Reply With Quote
Times have moved on a bit and we use these.
,Labcraft s 13 LED int lights
They aint cheap but 4 of them make the inside of a 40ft artic look like daylight. Strange thing is that during daylight they don't look up to the job but believe me they are
posted on 20/5/08 at 09:22 PM Reply With Quote
I've looked into in the past and the solar panels don't make enough juice for anything other than topping up the car battery unles you're prepared to spend serious cash on panels....
New Topic New Reply
