New Topic New Reply
Author: Subject: sierra lsd
euan
posted on 14/6/08 at 07:56 AM Reply With Quote
sierra lsd
Was looking for some info. Have a lsd from a 4x4 sierra which has a 3.36 ratio, was wondering if it is possible to change the crown and pinion from other sierra diffs with different ratio.
TimC
posted on 14/6/08 at 08:05 AM Reply With Quote
Swap you for a mint 3.62 plus £100!?
oldtimer
posted on 14/6/08 at 08:28 AM Reply With Quote
So the answer is yes, what are you looking for?
mookaloid
posted on 14/6/08 at 08:46 AM Reply With Quote
Are you sure? I was under the impression that the only ratios fitted to the 4x4 were 3.62 and 3.92
Mark
Kev99
posted on 14/6/08 at 09:02 AM Reply With Quote
If its a 3.36 it will be a 71/2" diff not a 7" one
smart51
posted on 14/6/08 at 09:40 AM Reply With Quote
Take the diff part out of your current diff and fit to a shell containing pinion gear of the ratio that you want. Swap the crown wheels of course.
A 3.38 LSD is very desirable. I'm sure there are plenty of people who will do a straight swap with their 3.62 LSD. (or even give you a cash sweetener)
New Topic New Reply
