New Topic New Reply
Author: Subject: Anyone made up thier own cornerweight guage?
mackei23b
posted on 3/7/08 at 09:51 AM Reply With Quote
Thinking of making my own up, but not the bathroom scale type.
Anyone had some success?
Mr Whippy
posted on 3/7/08 at 10:18 AM Reply With Quote
is it worth going to a lot of bother since unless you suffer from yo-yo dieting you will most likely need it only once.
the scales seem a cheap solution
posted on 3/7/08 at 10:25 AM Reply With Quote
Needs checked every so often springs settle particularly in the first 6 months use.
One way to do is make up a hydraulic load using a pressure gauge and a hydraulic cylinder
mackei23b
posted on 3/7/08 at 10:41 AM Reply With Quote
Any useful links for the kit?
Ian
indykid
posted on 3/7/08 at 10:51 AM Reply With Quote
didn't david jenkins make one out of a clutch slave cylinder and a pressure gauge off ebay?
i may be wrong on it being david, but that was the idea iirc.
tom
posted on 3/7/08 at 11:07 AM Reply With Quote
I looked at the idea, but then someone lent me one!
Here's where I found a design:
minimania
posted on 3/7/08 at 01:54 PM Reply With Quote
I was toying with idea of using a small cheap bottle jack as the cylinder.
posted on 3/7/08 at 07:07 PM Reply With Quote
BTW: It is worth doing - my car felt very unsettled, then I used the gauge and found that there was a diagonal bias (right heavier than the left at the front. left heavier than the right at the back.)
Balanced it out as best I could, and it felt a huge amount better afterwards.
New Topic New Reply
