So does anyone know when registration for 2010 season will open and how to apply?
Also when the 2010 calendar will be announced?
Got the car, done the ARDS, just need to join up and get amongst the action!
[Edited on 3/12/09 by steveiow]
Details won't be out this side of Xmas, best to contact Robin Knight at the 750MC. 01379 741641 he is the main man.
the Locost rep is Andy Pointer 07951 696172 hope that helps.
Andy has stepped-down but Im not aware if a new rep has been appointed yet.
Andy should still be able to help. If you have any specific questions about your first event etc drop me a U2U. I did the last 4 races this year -
my racing debut. What's the spec on the car - yes, I know its a Locost, but who built the chassis, engine and what drivetrain are you running?
Also, tune to MotorsTV at 21:15 tonight.
Welcome aboard Steve - see you out there next year.
Keep an eye on the 750MC website, I'm sure someone will post here also when it becomes available.
Dave Black
#28
did u like watching yourself win then david?
things should be up at the start of the year cus i was in a smiliar persition 2 u last yr when it was coming up to my first race
....my "maiden" race lap around Donnington was 2min9seconds
- you're well ahead of me already Max!
Haven't seen the footage yet, but it'll be on the tube / chanel 5 before long hopefully.
Been replaying it in my head since September
DB
What was really apparent Dave was the pace you had down Rev-out straight. You're drag was always better than those around you. Have the scrutes
had your head off???
What was also interesting was the varying angles of dangle through the chicane - poor Sian's car looked a mess through there in particular!
Hi
Higher speed carried through the corners down the straight is where the pace is coming from. Having the extra power of some will help even more next
year.
Cheers Matt
While we are on the subject of engines... my top tip for most improved next year: Dave Boucher. That motor he's built is an absolute beauty.
Mine was probably above average in terms of performance but if I got a drag on Dave I could pull-out down the Revett get alongside and he'd then
pull back in front. Front runners aside, he's the only one I couldn't pass that way. Proof positive that you don't need to spend an
absolute fortune with Randall!
Oh, I think Campbell will be quick too in a new bio car.
Originally posted by blackie
....my "maiden" race lap around Donnington was 2min9seconds- you're well ahead of me already Max!
Been replaying it in my head since September![]()
DB
Originally posted by TimC
While we are on the subject of engines... my top tip for most improved next year: Dave Boucher. That motor he's built is an absolute beauty. Mine was probably above average in terms of performance but if I got a drag on Dave I could pull-out down the Revett get alongside and he'd then pull back in front. Front runners aside, he's the only one I couldn't pass that way. Proof positive that you don't need to spend an absolute fortune with Randall!
Has anyone made a serious suggestion that someone is outside the rules?
And, even if you don't have your prerequisites you still don't need to spend the money - you could start by talking to Mr Boucher.
Simon,
I'm not sure if you're deliberately trying to come across as petulant.
It sounds like you may well justifiably have an axe to grind, but making the leap from my comments regarding Dave Boucher, or my well-meant jape with
Mr Black and either problems with illegal engines or 'free' engines could easily be misinterpreted and cause problems.
I was merely suggesting that if someone wanted a good race engine, built carefully within the regulations, they could do worse than talking with Dave
- I'm sure he and/or his contacts would want paying for the job - just not Randall prices.
Dear-oh-dear.
TC
Edit to add punctuation.
[Edited on 9/12/09 by TimC]
Simon,
It sounds like you may well justifiably have an axe to grind, but making the leap from my comments regarding Dave Boucher, or my well-meant jape with Mr Black and either problems with illegal engines or 'free' engines could easily be misinterpreted and cause problems.
I was merely suggesting that if someone wanted a good race engine, built carefully within the regulations, they could do worse than talking with Dave - I'm sure he and/or his contacts would want paying for the job - just not Randall prices.
Dear-oh-dear.
TC
