anyone have any info or opinions on the phoenix? if i eventually get into hillclimbing and sprinting, i am seriously interested in a phoenix! there is
no possible way i would risk (or be able to afford to) compete in my caterham and think i could make a good proffit if i sold it.
any opinions welcome.particularly on handling/balance,i absolutely love the styling/bodywork! cheers all
Only constructive thing I can say is I really like the fury/Phoenix and they are definitely on my "to build list".
You can't really be thinking about selling the catering van already?!
nice looking car but does the body make it significantly heavier? if it does then does it make it more slippery through the air at hill climb speeds? it's a bit of a trade off I think but on balance I'd rather not have the extra weight.
the caterham is awesome but i want to get into motorsport,and move house. caterham + those 2 is impossible!
The Phoenix was originally designed by Jeremy Phillips under his Sylva banner and was initially called the Mk4 Clubmans Striker. It comprised an all-enveloping body for the Striker chassis in a move prompted by the company's desire to capitalize on the racing success of the Striker in the 750 Motor Club's kit car championship as Jeremy knew a one-piece body would always be quicker than an op-wheel design and so it proved with the Clubmans car being 10 to 15 mph faster at the end of a decent straight over a cycle-winged Striker of identical power
interesting thanks
I like mine
They are nice lookers and surely a top choice for hill climbs. Only drawback is if you only have a slight off you could make an expensive mess of the
body.
Before I got my Stylus I test drove a Phoenix with the 4AGZE supercharged toyota lump in it. If only may arse wasn't too fat to fit in it
comfortably I'd have bought it there and then. Fantastic car.
what about weight with standard roll bar,no cage? zetec lor bike power
Wheres Jeff when you need him
Striker chassis, pretty bodywork.
Parts still available from Raw Striker who have taken on production.
Various body styles with subtle differences to front and rear.
Round tube chassis was a late development which was a bit lighter.
On fast circuits the aerodynamics make it quicker than a striker.
The other advantage is that you can hide an intercooler under the front bodywork, and package quite a lot of camping gear in the side-pods.
Matt
Weight wise mine was 476kg with a full tank and cage at SVA (GSXR1100 engine which is a bit porky compared to modern fare).
I got that down to 450 odd when I swapped to 13inch wheels and ACB10's.
A bit heavier now with a ARB's, turbo. But with a bike engine you won't be above 500kg.
Originally posted by Alfa145
Only drawback is if you only have a slight off you could make an expensive mess of the body.
"some people claim to be able to place the car more accurately in corners when they can see the front wheels."
well said this is why I loved my striker have driven a fury and had no idea where I was
I'm impressed with the level of opinions on here from people who have, likely, not driven one.
The RGB championship, until recently, the hunting ground for the Phoenix and the Fury. Remember this was a championship you could have used any kit
car variant and is run on all the main UK circuits (big and small) and yet.....there have been very few 7 copies and the championship was dominated by
the Phoenix (and Fury of course). An RGB Fury can be built to 400-410Kg (I believe 400 is the weight limit) so I presume a Phoenix could be down to
the same level.
Mine is a Zetec engined version (an actual Sylva) and has a live axle. The car weighs 560Kg with the Supercharger fitted. I don't know what the
equivalent Striker would weigh but I guess there maybe 10-20Kg in bodywork differences. The car is geared for 165MPH and I've seen 145MPH at
Snetterton (and still pulling) which suggests there is a distinct Aero advantage compared with a Striker. RAW actually put the Phoenix in a
Windtunnel and the results where significantly better than a Striker.
If you where doing Autocross where you are in 1st or 2nd gear and spotting cones then the 7 would have an advantage. On anything that looks like a
race track the Phoenix would be on a par and with anything over 110mph the 7 would lose out big time.
Originally posted by jeffw I'm impressed with the level of opinions on here from people who have, likely, not driven one.
The example video was to show what a lot of sprints look like. As you say the aero advantage doesn't show on sprints like this and I am equal or
slightly behind R500 Caterhams (mainly due to the bumps and my Live Axle). However....at Goodwood I am 3-4 secs in front of the Caterhams. We do 3
sprints at Goodwood in my championships.
This was a 97 sec run as I was lifting for the noise meters, the final run of the day was 90sec which is pretty quick around Goodwood. You can get an
idea of the top speeds though, the 90sec run was 5-10MPH faster . I don't do hillclimbing so can't comment on that.
Just for clarity the speeds shows are GPS speed on the datalogger and this was in low boost (250BHP at the wheels). The car is now 300BHP at the
wheels and should be able to get close to the FTD times at Goodwood when there are no single seaters.
[Edited on 16/2/13 by jeffw]
All well and good, but we need to maintain some perspective, I think - the OP is taking about a Sylva as a budget alternative to a Caterham
Supersport, so he won't be setting out to beat R500's with a 300bhp turbo engine?
That said, you certainly won't find me criticising the Phoenix - it's just a question of whether the Striker would not offer a slightly more
practical choice, at a budget level, than the full-bodied car?
I guess it might come down to where he is located, geographically, and hence whether it's mainly sprints or hills that he'll be competing on
- if it's the former, the longer straights and the lack of anything harder than a traffic cone to bump into if you get it wrong might tip the
balance in favour of the Phoenix?
But then, like I said... if you like the look of the Phoenix, that's a good enough excuse to favour it, anyway.
the final run of the day was 90sec which is pretty quick around Goodwood... I don't do hillclimbing so can't comment on that.
thanks sam. yeah, its a budget alternative im after which is good for track days,sprints,hills etc
my local venue is barbon which is short under 30 secs but i do go to harewood a fair bit. im located in north west near kendal and lancaster
Originally posted by Sam_68
All well and good, but we need to maintain some perspective, I think - the OP is taking about a Sylva as a budget alternative to a Caterham Supersport, so he won't be setting out to beat R500's with a 300bhp turbo engine?
Google tells me that Goodwood is 2.4 miles in length so that'd mean you'd be averaging about 96mph?
It has just dawned on me the Sam_68 is the same guy as on Pistonheads (who is now Lastpost). Daniel, if you want to discuss please U2U me otherwise I'm done on this thread.
Originally posted by jeffwSupercharged not turbo'ed and 96MPH from a standing start.
Hi
If it is a motorsport variant your after then there is only one model to hunt down and use, The Stuart Taylor ( STM ) versions made specifically for
competition use.( very few and rare ) As with all reference to the Furies and phoenix and strikers used with great success in the 750Mc Kitcars and
RGB championships, They where all specials non of the highly successful ones are based on what you can buy direct from current manufacturers JPS RAW
Fisher Etc Etc.
However if it is the shape / style you are liking then track down Rob Johnston at Cyanna cars. He is the only person who is currently manufacturing
this style of car purpose built for competition use.
Cheers Matt
Originally posted by procomp
However if it is the shape / style you are liking then track down Rob Johnston at Cyanna cars. He is the only person who is currently manufacturing this style of car purpose built for competition use.
Cheers Matt
Hi
If it is a motorsport variant your after then there is only one model to hunt down and use, The Stuart Taylor ( STM ) versions made specifically for competition use.( very few and rare ) As with all reference to the Furies and phoenix and strikers used with great success in the 750Mc Kitcars and RGB championships, They where all specials non of the highly successful ones are based on what you can buy direct from current manufacturers JPS RAW Fisher Etc Etc.
Hi
Cheers Matt
Call Tim Gray Motorsport. Tim often knows where to find the desirable chassis'.
Here's another uninformed view from someone who's never seen one on the move: they look great.
Secondly, any car that you compete in has to be considered potentially expendable, and by the time you trade in the 'Van and get something else,
you could have (gasp!) had an off in the new one, but be out as much, or more money, overall, than if you'd kept the original car and pranged
that one. Justifications, therefore, are not necessary, in my opinion!
