Racing Helmet Help - Snell sticker
TimC - 1/12/07 at 09:30 PM
Hi folks
I'm currently looking at a helmet which is a U.S. equivalent of the Bell Sport 4 (Bell is apparently Zamp in the U.S.) helmet. Everything points to the fact that its Snell 2005 accredited which is great, but it's only marked with FIA 8858 which is the FIA's Hans-ready standard. What's the deal with the Snell Sticker - should one come with the helmet or do I have to get it from a scrute?
RK - 1/12/07 at 11:48 PM
Bell and Zamp are sold in the US; one does not replace the other, although they could be made in the same factory. As far as I know (and I am not an expert), the Snell sticker itself has nothing to do with a scrutineer. The helmet is either approved for certain activities or it's not, and a scrutineer will check for its presence at the event.
You have your European standards and approval stickers on helmets, the US has theirs.
bjw970s - 2/12/07 at 12:46 AM
Hi,
The only sticker a scrut puts on is an 'MSA' one. I haven't got a 2008 blue book yet so I couldn't say what helmet standards are approved, but mine is a SNELL2005 which is still valid.
You would need to get hold of a blue book to be sure before buying. If you want to get a cheap helmet in the UK try the show next weekend or AUTSPORt in Jan as they do do offers.
Brian
TimC - 2/12/07 at 09:00 AM
I can't make Autosport this year as I've got exams in the same week - fiirst one in 4 that I'll have missed. I did look around last year and none of the helmets were as cheap as the US route - providing that they can supply a SA2005 sticker for a helmet which IS on the list.
I'm sure SA2005 has a few seasons in it left since there isn't a higher Snell standard at this stage and SA2000 was valid for '07 too.
TC
Spot the difference:
Bell Vs Zamp
Bell Vs Zamp
[Edited on 2/12/07 by TimC]
simes43 - 2/12/07 at 10:50 AM
If you are going to the trouble of importing a helmet from the US, have a look at the Aria GP5. Better quality than the Bell and they are Euro spec Snell.
http://www.speedwaremotorsports.com/helmet/arai.asp
I imported mine last year and also avoided the latest con contrived by DT and GPR. The HANS post locating charge.
TimC - 2/12/07 at 11:49 AM
Err - Less than £180 plays more than £450. I'd expect the Arai to be better!
simes43 - 2/12/07 at 12:08 PM
When your Bell visor pivot continues to revolve round and round without coming off............
There is a huge difference in quality between the two. I looked at Bell before deciding on the Aria. The Bell just feels as if it could come a part in your hand when compared to the Aria
Make sure if you go the Bell route that the helmet model is available in the UK.
You can then use DT or GPR if it fails. A friends just has.
TimC - 3/12/07 at 09:53 AM
In case anyone alse is interested, I'm now looking at a SA2005 helmet for about £145.
It won't be Arai quality, but is obviously of sufficient standard to pass the tests - ideal if money's too tight to mention!
U2U me if interested.
TC
bjw970s - 30/12/07 at 08:55 PM
I have used Bell Sport for the last 6 years over 2 helmets and never had a problem. I will be using it open cockpit this year so we will see whether that makes a difference.
145 quid sounds pretty good if, you can get the appropriate certification.
[Edited on 30/12/07 by bjw970s]
TimC - 30/12/07 at 09:32 PM
All sorted, arrived, everything - £154 delivered included a protective carrying bag.
