hi i have just been trying to fit a couple of brake calipers on my MK and they will not fit. i believe they are off a lotus elise so iam now after a
front set up calipers,disc's and pads. so if anybody has a set lying around drop me a line other than that what is the best set up to go
for?????
plus they have got to fit in my 15'' wheels.
cheers steve
[Edited on 2/7/11 by whitstella]
Hi Steve, they fit with the aluminium adaptors and some washers to space them out.
your aluiminium spacer has a rather fetching wood grain effect !!
Is it because the radial mount bolts from the caliper interfere with the hub bolts, or is it the bracket will need a radius on it to allow the caliper to sit in deeper? If it's the latter I may be able to help...
Steve, you have U2U.......
Phil
Do you mind me asking what you paid for the calipers? As I've got a pair in the garage with pads..
