Just testing an MX5 based Haynes roadster I acquired part built and am turning into a track car.
On it's first road test last night, the temp gauge (original dash) got up to 3/4 way and stayed there. Fan didn't cut in and it didn't
seem too hot under the bonnet.
It seems these days the gauges are often not proper gauges, and are ecu driven.Not sure if its the case here as it stayed rock steady at 3/4 way which
seemed a little odd. It does start from the bottom when cold and rise with the engine run time, so I know it is not entirely broken.
Can anyone offer any experience from their car, or do people all switch to different dashes and gauges etc ?
I have the Mazda 1.6 from an Eunos (MX5) in my car. It's completely standard and I didn't use the original gauges. I have a Racetech
mechanical water temperature gauge and a VW Polo radiator. It runs around 80-90 Celsius and the fan only cuts in when the car is stationary for over 5
minutes or so.
The VW Polo fan switch cut's in at 92 Celsius.
Evening
Nothing to do with running hot because mines not running
But question is what is the performance like? My build is currently a 1.6, I know a 1.6 wont set the world on fire but do they go ok?
Gary
Originally posted by gary gsx
Evening
Nothing to do with running hot because mines not running![]()
Gary
