Hi,
I have a 4 month old (if that) MBE 995 Dash display as per: http://www.sbdev.co.uk/Engine_Management_Systems/ECU_Details/MBE995/MBE995.htm
Don't need it now as i am fitting a Dash2.
Works with the 9A4 and 9A8 ECU's comes with can interface cable so it is directly plug and play, can display - RPM, voltages, temperatures,
pressures, gear selection.... what ever is currently connected to your ECU
Programmed through your ECU's normal software, very easy to set up.
Currently set to 10,500 Max shift light.
From SBD this is £385 plus £153 for the Connection loom. as per:
http://www.sbdev.co.uk/Price_List/Management%20System%20and%20Fuel%20System%20Price%20list.pdf
It is in brand new condition, probably even have the original packaging for it!
Looking for £450 posted for the complete package.
John
Now removed from Car so ready for sale
Can it display MPH?
Yes it can if a speed sensor is fitted to the Ecu.
SOLD
