Kriss
| posted on 31/5/09 at 05:02 PM |
R888 Track day pressure?
Just checked my pressures (using a mini Draper Guagae) and I am currently rocking 20 PSI cold.
I have a few hours at Brands Hatch tomorrow and not sure if I shoudl drop them a tad or just go with how the car feels?
any suggestions etc would be great.
Think I will end up rocking 19-20 psi hot
shaun fulcrum
| posted on 31/5/09 at 05:11 PM |
20psi hot sounds right to me ;] hope you have a good day (wish I was going!).
Guinness
| posted on 31/5/09 at 05:14 PM |
I'd start with 16 cold and work from there. The joy of a trackday is that you can experiment.
Do a few laps at 16 cold. See what they are when you come in. Stick a few more in, try that. See if it feels any better / worse.
Repeat until
Mike
marmot0
| posted on 31/5/09 at 05:32 PM |
See you there will be there all day in a bright green striker
Kriss
| posted on 31/5/09 at 06:00 PM |
willc oem say hi, my family bought me the evening session ut will be rocking up at 3.30ish
thought I was in the right ball park figure, will test and learn
cheers
kriss
skydivepaul
| posted on 31/5/09 at 07:50 PM |
i used to run at 15-16 psi cold. would be up to 18-20 once hot. worked ok for me with mk indy R1
cheers
Paul
http://www.smartideasuk.com
http://www.smartmapping.co.uk
HD CCTV
IP security systems
access control systems
