Author: Subject: MK windscreen
Tinks1
posted on 6/7/09 at 08:08 AM Reply With Quote
MK windscreen
Can anyone who has fit a windscreen to an MK Indy tell me what angle the screen to side panel... I ask because I have the Robin Hood screen and bracket, the bracket is at 25deg bit this looks stupid if i trial fit onto the scuttle the angle looks about 10deg....any feedback would be appreciated.
John
YQUSTA
posted on 6/7/09 at 09:24 AM Reply With Quote
Here is mine I threw the robin hood supports away they do look wrong to me too.
Image deleted by owner
miikae
posted on 6/7/09 at 10:03 AM Reply With Quote
Just had a check on my RH and its approx 64 degrees from the horizontal, the bottom of the RH bracket should be parallel to the scuttle joint.
Hope this helps
Mike
If it can be done it i will be done .
Marcus
posted on 6/7/09 at 11:28 AM Reply With Quote
I spent ages on CAD and making cardboard templates for mine. Finally settled on 63° from the horiz. (27° from vertical) just 'cos it looked right!
Looking at other cars, mine seems slightly more laid back, but I like it...
Marcus
Because kits are for girls!!
