Author: Subject: Another Windscreen question
Tinks1
posted on 7/7/09 at 12:18 PM Reply With Quote
What screws have you used to attach the windscreen to the pillars.
The windscreen frame looks very small in cross section to get a decent screw in, and there appears to be a lot of resistance from the rubber under the screen. I am concerned that the this will not be a strong section. Any comments appreciated.
John
Mr Whippy
posted on 7/7/09 at 12:26 PM Reply With Quote
I'd tap a thread into the alloy frame, say an M5 thread and use countersunk screws going through the support. Use 3 -4 per side
whitestu
posted on 7/7/09 at 12:28 PM Reply With Quote
Mt Caterham screen has rivnuts in the frame.
Stu
YQUSTA
posted on 7/7/09 at 12:42 PM Reply With Quote
I used 3 m3 tapped into the frame.
Tinks1
posted on 7/7/09 at 01:48 PM Reply With Quote
Using something as big as M5 do they not break through and hit the glass. I am worried that M3 will not be strong enough to overcome the stress from the rubber
mangogrooveworkshop
posted on 7/7/09 at 08:15 PM Reply With Quote
I use blind studs that are set in the frame and dont crack glass
whitestu
posted on 8/7/09 at 02:22 PM Reply With Quote
I would agree that this is the best way to do it.
I had to be very careful with the length of the allen screws going into the screen.
Stu
