bi22le
posted on 25/1/11 at 04:47 PM |
Yoko Prada Spec 2 tyres on track
Hi all,
Anybody used these on track?
How do they compare to Toyo T1Rs or similar?
Thanks,
Biz
Please read my ring story:
will121
posted on 25/1/11 at 05:59 PM |
not used them on a 7 but seen a set on a Ford Puma where they the rubber tread blocks tore up quite bad. may be down to the size/depth of the tread
block movement and do feel quite soft.
that was a warm dry trackday, might be different on a lighter 7 and damp track or better when worn down a bit
![](http://i283.photobucket.com/albums/kk285/williamholmes/pradatyre.jpg)
koiking125
posted on 25/1/11 at 07:01 PM |
I went through 2 sets on my EP3 Type R in 3 years, they were much better than the Bridgestone's it came with, much more grippy.
Kev
MK Owners Club Member (Frosty) No.1159
bi22le
posted on 25/1/11 at 07:37 PM |
Thanks for the feedback. Any one else??
I am just trying to double check there are no alturnatives before I shell out £300 quid for R888 at twice the price!!
BenTyreman
posted on 25/1/11 at 07:54 PM |
On the road, not the track, but I think they have slightly more dry grip than the T1S and loads more wet/damp grip.
beaver34
posted on 25/1/11 at 08:04 PM |
Yes r1r toyos
franky
posted on 25/1/11 at 08:26 PM |
or the new r1-r's.
mikegsi
posted on 25/1/11 at 09:15 PM |
just put a set of these on my MK, for mainly road use, ive yet to hear a bad work about them on road, but i wouldnt class them as a track tyre -
though they may be ok on a 7 type car due to less weight.
i paid around £37 each for mine delivered in 195/50/15
for a road legal semi slick i would deffo recommend the 888, or the re070 if they come in your size. i also looked into the r1r, but when i saw the
price of the parada's i just went with them
martyn1137
posted on 25/1/11 at 09:44 PM |
Had a set of the Yoko's on my daughters Fiat Bravo, road use only but a very good tyre for the money. Wet and dry grip excellent.
As they are cheap you could give them a try but if you are looking purely for track day performance go for a dedicated motorsport tyre.
