marcman
| posted on 11/5/13 at 05:51 PM |
High revs after brief cool down
It's well recognised high revs before getting up to temp can cause engine damage but can anyone comment on what could happen if you drive hard
using high revs after a 30 min ish cool down?
Did it today and in retrospect, probably wasn't the wisest thing to do so just thought I'd ask.
Engine is a 2.1 pinto. Water temp got down about 50deg ish, then set off at full chat. Anyone know if doing this would have been likely to cause
engine damage? Probably worrying about nothing but any comments gratefully received!
Marc
jacko
| posted on 11/5/13 at 06:06 PM |
I would think you will be ok it's not like setting of from cold and the oil will still be around the engine
And welcome to the mad house
Jacko
marcman
| posted on 11/5/13 at 06:11 PM |
Thanks, had hoped it would be ok!
Aaron_n_Sim
| posted on 11/5/13 at 06:27 PM |
Welcome aboard
Would have thought oil temp was more important but same as jacko said it wasn't from cold should be fine, the engine I'm using came out of
one of my Capris, it's been ragged for yrs but looked after and is still a really good lump, good, strong, tweakable engines.
Aaron
Work to Live don't Live to Work
beaver34
| posted on 11/5/13 at 06:43 PM |
After 30 mins you would still have warm oil
Will be fine
marcman
| posted on 11/5/13 at 07:42 PM |
Knew I'd get well informed comments on here, hence joining. Thanks guys
