Slimy38
posted on 22/5/14 at 01:36 PM |
Engine clean
I want to give my engine a bit of a clean and paint before it goes into the chassis, are there any good tips on how to do it? In a previous life I
would have used Gunk, but I get the impression the new 'environmentally friendly' formula is nowhere near as good as before. I've
had a quick go with IPA, and while it is reasonably effective I'm guessing I'll need something more to get to the real muck.
It's an MX5 engine (so predominantly alluminium I think?) still attached to the gearbox, and I would prefer to leave things like that. The muck
seems to be general grime with a slightly oily undertone. I suspect I'm in for a long labour job, with all the nooks and crannies I'm
thinking spray bottle and a toothbrush rather than anything quick.
[Edited on 22/5/14 by Slimy38]
johnemms
posted on 22/5/14 at 02:17 PM |
While on the chain n pully in the air ..
Put cardboard down..
Put a large drip tray under it..
Nice big brush & paraffin
Compressor on - Blow clean .. Job Done ..
Own chassis & Build - First time pass!!
"7's" aren't really "cars", they are 'experiences"
Slimy38
posted on 22/5/14 at 02:38 PM |
Mmm, paraffin... old school but I like it!! Will it need any further cleaning if I want to give it a paint? I'm assuming I can't paint on
paraffin.
pewe
posted on 22/5/14 at 02:45 PM |
Some say that Harpic Power Plus toilet cleaner does a good job on ali.
Suggest you try it on a small area first and see how it goes.
Alternatively a mix of petrol and paraffin works well, you can then degrease with Meths (doncha just love the taste?)
Using either method wear protection and avoid naked lights!
Cheers, Pewe10
ReMan
posted on 22/5/14 at 03:20 PM |
petrol or parraffin for me to , old school, smelly, dangerous but it works.
Then use a detergent/washing powder and rinse
www.plusnine.co.uk
Ugg10
Thanks for posting this, very timely, I am about to do the same job with my engine over the next couple of weekends, mine is a bit more oily than
yours by the sound of it though.
Agree the hoist/crane to get it at waist hight will help the back and the drip tray/cardboard/blanket under it will keep the mess down.
Cleaned up some throttle bodies last weekend with road grime/oil/carbon on them with driveway oil patch remover + wash off with water, seemed to work
well and then went over the top with petrol (in a well ventilated area) to degrease and left to air dry. This will be my first route, if that does not
work then I will try the parafin/petrol mix.
19sac65
posted on 22/5/14 at 05:14 PM |
Deisel works well too
rotax78
posted on 22/5/14 at 05:22 PM |
I've used this stuff (swarfega oil & grease remover) worked really well and cheap
linky
[Edited on 22/5/14 by rotax78]
Andy S
posted on 22/5/14 at 06:03 PM |
Morris lubricants Lydian degreaser - excellent stuff, brush well in and pressure wash off.
ste
posted on 22/5/14 at 07:11 PM |
MX5 engines are iron not ally. I bought some rust de-ox gel and parts cleaner off Mistral http://mistralni.co.uk/
cheap and very effective.
wire brush in a drill to get heavy soiling off, then soak with parts cleaner, a paint brush that has the bristles trimmed to about half an inch long
makes light work of it. then jet wash it, then cover with deox gel and leave over night.
then jet wash off again and dry with air then paint asap.
Slimy38
posted on 22/5/14 at 07:19 PM |
Ah, I wondered if that particular wiki entry was correct, thanks. Do you know if the gearbox and bellhousing are aluminium?
ste
posted on 22/5/14 at 07:24 PM |
yes they are, the only iron part of the setup is the block. I'm part way trhrough cleaning & painting mine as we speak for final fit.
Slimy38
posted on 22/5/14 at 07:30 PM |
Excellent, thanks. I don't suppose you could post a pic or two when you finish yours? It will give me something to aim for!!
perksy
posted on 22/5/14 at 07:36 PM |
Parrafin or Fairy power spray
Scuzzle
posted on 22/5/14 at 08:30 PM |
That Fairy Power Spray is really difficult to get, my local supermarkets don't keep it on their shelves at all which is a shame as it's
good stuff.
adithorp
posted on 22/5/14 at 08:39 PM |
Aldi have/had sonic wheel cleaning brushes in recently. They look like a jumbo electric tooth brush with a selection of brush heads. I did wonder what
they'd be like for this sort of stuff.
http://jpsc.org.uk/forum/
Ugg10
posted on 22/5/14 at 08:42 PM |
linky
Looks similar to the path cleaner I used.
Slimy38
posted on 22/5/14 at 08:56 PM |
I did think about those, but I reckon the head would wear away really quickly and with no prospect of spares it would get really useless really
quickly. At least a JML equivalent would get spares.
What I have done is order a handheld steam cleaner, one of the other things I was reading suggests steam is very effective. But that was on the
assumption the engine was aluminium, I'm not sure water and cast iron is a good combination. I've seen steam cleaned engine bays, and they
look awful if the metal is left to rust.
threadbare wallet
posted on 23/5/14 at 06:10 AM |
For the nooks a cranneys ya cant reach use cola! Let it sit in there for a while and it will clean anything off! I use to use that on bike parts on
despatch bikes that got really grubby and always came up like new......still drink to which is worrying
[Edited on 23/5/14 by threadbare wallet]
Very few things are "really" needed.
Ugg10
posted on 23/5/14 at 06:34 AM |
That will be the magic that is phosphoric acid, ever done the 2p test over night!
[Edited on 23/5/14 by Ugg10]
mark chandler
posted on 23/5/14 at 07:43 AM |
When I cleaned a very grubby, inside and out rover v8 I used drain cleaner, it fizzles a bit but really gets the job done.
ken555
posted on 23/5/14 at 08:40 AM |
Cillit Bang and a jet wash
to
