fha772
posted on 9/10/14 at 09:25 AM |
Wanted, Sierra rear hubs, disc brake type, for a 7.5 diff.
Hi all,
Has any got any Sierra rear hubs, to go with a 7.5" diff and 105mm shafts?
I'm not bothered about the brake discs and calipers, but they're there, I'll have them if the price is right.
Cheers Frank.
http://www.ppcmag.co.uk/forum/viewtopic.php?f=47&t=6743&start=105
mcerd1
posted on 9/10/14 at 09:28 AM |
do you mean the 108mm CV joints ?
fha772
posted on 9/10/14 at 09:31 AM |
Bugger!!
Yes, I mean 108mm!!
mcerd1
posted on 9/10/14 at 09:41 AM |
as far as I'm aware the 108mm CV's are only used on the 2wd Sierra Cossie
(these also have lugs to suit 273mm discs - which can be an issue for smaller wheels)
all the other sierra's, Granada's and Scorpio's used the 100mm CV's - so it limits you choice a bit
one other possibility is the BMW 3/5 series - lots of them use 108mm lobros...
fha772
posted on 9/10/14 at 10:00 AM |
Yes, it's a cosworth diff and shafts that I've got.
Do the BMW hub carriers bolt onto the swing arms, like the Sierra?
I thought the bearings were pressed into end of the arm on the BMW.
mcerd1
posted on 9/10/14 at 10:43 AM |
yes I think that's right - but have a look at the rear uprights / bearing carriers that GKD use - overall I think it looks neater than the
bolt-on sierra version
as for the cossie hubs, if no one here has any they come up on ebay every now and then - but the cosworth name does seem to add a fair bit to the
price
[Edited on 9/10/2014 by mcerd1]
Non custom
posted on 10/10/14 at 08:53 AM |
I have some 108mm stub shafts here if that's what your after as funnily enough I need the smaller 100mm type
