New Topic New Reply
Author: Subject: British Sprint Championship - Pembrey 2nd June
jeffw
posted on 3/6/19 at 06:48 AM Reply With Quote
Mixed weather conditions, I was 4th fastest in T1 (very wet), 6th in T2 (less wet) and ended up 8th in the top 12 Runoffs (best result so far).
T1 wet run
https://www.youtube.com/watch?v=MHmYtFC40k0
External view
https://www.youtube.com/watch?v=lCJlLFAEPY0
Fast run in the Runoffs
https://www.youtube.com/watch?v=S15P1-gVLY4
[Edited on 3/6/19 by jeffw]
HowardB
posted on 3/6/19 at 07:34 AM Reply With Quote
that does look a little damp - sounds nice though,. well done on the result
Howard
jeffw
posted on 3/6/19 at 07:50 AM Reply With Quote
HowardB
posted on 5/6/19 at 05:03 PM Reply With Quote
I know that it is chalk and cheese but how does it compare to the Phoenix?
Howard
jeffw
posted on 5/6/19 at 08:06 PM Reply With Quote
Completely different to drive, I'm still adjusting to the Zeus. Loads of revs/turbo power but you have to drive it really hard to get the aero to work which is where the speed is. The Phoenix was a lot more torque and you had to drive it on the throttle in the corners, balancing the car. The Zeus is brake to the apex and then power out the other side, no balancing at all.
HowardB
posted on 5/6/19 at 08:11 PM Reply With Quote
Thanks for the info. I did wonder. As I said. Congratulations.... genuinely impressed
Howard
jeffw
posted on 5/6/19 at 08:50 PM Reply With Quote
Still 5+ secs off where it should be per lap. Driver needs to be 'educated' further
New Topic New Reply
