MK9R
| posted on 26/8/08 at 06:33 AM |
Battery cut off switch
Does it have to be FIA approved or will one of the cheapo ones be OK??
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
| posted on 26/8/08 at 07:07 AM |
for SVA, there is no requirement to meet any standard -they are fitted a a second means of immobilisation.
for racing it may be different, dunno.
minitici
| posted on 26/8/08 at 07:13 AM |
"FIA" Style with the secondary contacts and dump resisistor, will save your alternator if you use the cut off switch to kill the engine
when it is running.
MK9R
| posted on 26/8/08 at 07:19 AM |
when it is running.
i've just thought that, after reading the specs
Cheers Austen
RGB car number 9
www.trackace.co.uk
andrews_45
| posted on 28/8/08 at 08:13 PM |
If you go back through my previous posts Matt put a diagram on how the FIA killswitch is wired...
FIA type is defo required for racing.
procomp
| posted on 29/8/08 at 07:08 AM |
Hi i will add the diagram in case. It may help anyone doing a search on the subject. .
Cheers Matt
  Basic wiring diagram for the FIA version of the battery cut off switch.
[/img]
