Track Day upgrades/advice
bassett - 27/5/11 at 12:52 PM
Hi,
Few questions in an attempt to bullet proof my MNR Vortx R1 for a worry free track day;
Will i need fluid higher than dot 4 if its fresh and im doing just a morning/afternoon session?
Would any one recommend getting a cheap spare set of wet weather friendly wheels/tyres than the current R888's?
Any way to help with noise control on the spot if it breaks the 101-105db limit?
Adam
PAUL FISHER - 27/5/11 at 01:42 PM
You will be fine with your current brake fluid, R888's a not as bad as some people make out in wet conditions, they just don't like standing water (puddles), so just adjust your speed in wet conditions you can still have a lot of fun, and a DB killer is the quickest cheapest way of reducing noise, I used one of these below, available in different sizes depending on your exhaust size
MOTORBIKE MOTORCYCLE EXHAUST BAFFLE RACE CAN db KILLER | eBay UK
Service Champions - MOTORBIKE MOTORCYCLE EXHAUST BAFFLE RACE CAN
db KILLER
BAFFLE - EXHAUST DB KILLER / ROAD / RACE LEGAL CAN | eBay UK
adithorp - 27/5/11 at 03:06 PM
I've been running dot4 for 3 years and never had any problem (track days and Alpine passes included).
888's are OK as long as your carefull.
Which R1 do you have? If it's a 5vy have you modded the breather?
mark chandler - 27/5/11 at 03:31 PM
Also have you a sump baffle, on blades you over fill oil by 200cc so best have a search on here to see if that also applies.
Regards Mark
Nick DV - 27/5/11 at 04:52 PM
Personally I would put in fresh oil and change filter before, and I would also do it after, but that's up to you.
Cheers, Nick
bassett - 27/5/11 at 05:30 PM
Cheers guys and its a slightly older 5pw so no breather mods and has has a baffle from day one.
