Anyone going to this, i did one last last month and was the only kit car there. These are cheap and good fun and a great way to play with the rear
end.
The marshalls will give you free instruction and there are loads of different circuits.
They even have tyre changing facilities.
I'm going again to this one be good to see more kit cars there showing the datsuns that they arent the only ones who can drift.
Excuse the masking tape flapping about
i would if they had the same surface as oulton park
The pod promised to repair all the pot holes before this event, we will see, although i didnt find too much of a problem.
I think afj is referring to Oulton parks special low friction drift circuit,you can drift like a pro,without putting your car under too much
strain,its also very kind on your tyres
oh, that sounds clever.
