anyone fit a flat shifter all i need to know is where i tap into the trottle bodies on a hayabusa for the vacum to operate the trottle blipper
whats your email address ?
I can email the flatshifter destructions to you
or
http://bristolkitcarclub.co.uk/smf2/index.php?topic=416.0
[Edited on 31/3/11 by T66]
or
Flat shifter told me to use the balance vac hose connection on number one body that is blanked off unless balancing the bodies, but i had to srill it
out to 2.5mm first to allow enogh air to trigger the system
mine was a gxsr 1000 though.. the shorter the vac hose the better too....
There was a flat part on my Busa T.B's that was obviously there to be drilled and tapped for a fitting for whatever.
Jason
