Hi guys.
I am looking at doing an oil change (first one I've done on the car) and was wondeing what oil I should use with the Blade engine? It is
currently sitting at about a third of the way up the fill window but I was thinking of filling it to about 3/4's up the window. I figured it
would be best to slightly overfill it to reduce oil surge on the track?
I use this in every car I work on, bit pricey but its the best oil Ive ever come across, plus it smells good! Makes a noticeable difference I find.
http://www.demon-tweeks.co.uk/motorcycle/4-stroke-oils/motul-300v-factory-line
Thanks mate. I have used Motul in most of my other cars so I will go get me some.
