Hi Guys,
How much movement should i expect with a live axle striker from the rear axle and the prop shaft?
I have a fairly narrow tunnel, and my prop is currently fouling on the tunnel wall on bumpy roads or hard left corners.
The noticeable point is that my prop is not central down the tunnel, but i'm not sure how i fix this other than "modifying" the tunnel
wall with a big hammer as obviously the prop can only fix to the diff, and i can't exactly move the axle left or right.
Again, a bit concerned as i don't really want my prop fouling on the car, so what is reasonable movement, what should i expect?
Sylva Striker
2.0 Blacktop Zetec
5 Spd Type 9
Mk1 Escort live (english) rear axle
A couple of pics:
You need an adjustable Panhard rod. You will be able to get one from Raw or Fury Sportscars. This will allow you to adjust the position of the live
axle and stop the rear flange rubbing against the tunnel.
[Edited on 1/8/14 by jeffw]
The problem with that though is that my axle is aligned in the middle of the car, if i move the axle, effectively my track will be out. I'll have more offset one side than the other
Is the track currently spot on dead centre tho?
pretty sure it is measuring from front wheels to back....
i'll have another check though.
In the top picture the yoke seems to be off-centre.
My axle rotates ever so slightly (slight play in all the bushes) but it does not move sideways other than by adjusting my panhard rod. It is not central in the tunnel on car as the diff is offset from the centre.
I presume you do not have a Stiker/Phoenix then.
Live Axles in these do move and without it being square in the tunnel they will hit the side.
as i understand it, the prop shouldn't be perfectly aligned, the pinion on the diff should always be a little off centre so the bearings in the
prop are NEVER perfectly alinged, otherwise they'd wear out pretty quick. the out of alingment makes them last much longer.
you'll notice that the pinion is never centred on the axle either.
the original book locost had a slight widening of the tunnel to accomodate this i think?
is your axle centred correctly?
Edited for wrong Edwardian Frenchman.
Originally posted by blakep82
as i understand it, the prop shouldn't be perfectly aligned, the pinion on the diff should always be a little off centre so the bearings in the prop are NEVER perfectly alinged, otherwise they'd wear out pretty quick. the out of alingment makes them last much longer.
ok so i've gone and had another look and turns out you lovely people must just be right for a change!
Question is, how do i go about changing the static positioning of a rear axle?
My setup looks something like this drawing an artist did for me:
So i have brackets where the suspension meets the axle, another arm that is connected to the axle on the right side and the chassis on the left, and
then four trailing arms (two from suspension mounts to rear chassis, two from hub to centre chassis).
Apologies for my stupidness in advance, i don't know much about axles/suspension etc.
[Edited on 1/8/14 by pekwah1]
You need to be able to adjust the bar between the 2 V shaped brackets.
I assume something like this?:
http://www.ebay.co.uk/itm/like/131041326537
Edit - maybe not, that looks like a chassis mounted adjustment.
more like this - http://www.rallynuts.com/nissan-micra-k11-suspension/whiteline-panhard-rod-kit-adjustable.html
but to suit the width of yours!
[Edited on 1-8-14 by loggyboy]
Awesome, so assuming that by reducing the length of that bar, it will pull the whole axle towards the chassis mounted side of the car.
Originally posted by loggyboy
Or just move the mounting point over.
Also remember that Jeremy designed the car to have metalastic bushes. This was to give an element of roll resistance. If you remove them and replace them with rose joints you would need to run an ARB on the rear.
I use rose joints at both ends of my panhard rod for adjustment. I do have rose joints on one end of all the other links but use metalastic bushes the
other end. I use good quality joints and check axle and chassis brackets for cracks after every event.
my striker cracked the axle where the panhard bracket is welded to it even though it is fully rubber bushed(normal metalastic bushes on the rear
facing arms, not sure what the other bushes are)
that's always put me of the idea of rose jointing even just the panhard rod.
