As above
Cheap prefered.
are you looking for something thats ready to fit or something that would need rebuilt/new valves etc ?
also is that a 2.0 pinto head and do you want an EFI or a carb'd one ?
I was palnng to build a head up to go on my pinto with a cam and some head work I'm running 40 dcoes but currently looking into fireblade carbs
I do have one from a 2.0 carb'd pinto, but it would need completly redone
(came off an engine I found in the shed, I think its from my dad's cortina that died in the 80's...)
the EFI heads have better std port shapes, but if your going to work on that then either type would do
the big problem with my one is the postage would be more than its worth
hi ive got a 2L pinto head off of a cortina nr leicester J20 M1 £50 07971122662
U2U sent
I got a whole 2.0 pinto engine if you want it. FREE. Just come and take it away.
Cant say what state its in, but its more or less a complete engine, no ancillaries or manifolds
Its not seized, and does turn over.
Cambridge end of the A428, so not far away either!
As said, its a freebie. I want the space back!
Well perhaps a few tins of beer might be welcomed! (nothing drastic.. would be a nice gesture)
[Edited on 2/9/2011 by wilkingj]
