VW Polo 2010 Lights
maskell01 - 3/12/15 at 08:24 PM
Hello again one and all!
Im having a bloody nightmare with the other halves VW polo.
On the dash a light comes on to say that there is a tail Light bulb is out.
Turns out it was, the drivers side.
Started unwinding the plastic screw that seems to hold Japan in place, and the bugger came back on.
Every time i tapped the cluster, the bulb kicked in.
Lost my temper and replaced it!
Still The same!
Has anybody seen this before?
Can anybody shed some light on this?(Excuse the pun)
Cheers All
Aaron
perksy - 3/12/15 at 08:28 PM
Dodgy bulb holder ?
Dodgy connection or earth ?
rash12 - 3/12/15 at 08:55 PM
i bet the connector onto the lamp holder is corroded vw golfs have the same problem mate
maskell01 - 3/12/15 at 09:03 PM
it all looked ok but in all fairness, it was a quick job as i felt like setting the bloody thing on fire!
could blame it on dodgy wiring!!!
britishtrident - 3/12/15 at 11:47 PM
Fairrly common problem apart from careful abrasive cleaning I have used a product called "Corrrosion Gone" followed by contact grease.
It can also be caused by some cheap and nasty bulbs that have dimensions that aren't to spec or have some sort of lacquered coating.
