I've decided to change my diff from 3.38 to 3.92 and despite a seemingly fair bit of info out there its a bit of a mine field, so I have decided
to capture what I have read and I hope you guys can correct anything that's wrong.
I will restrict the discussion to the push in shafts which in turn means only drum brake cars (unless some clever person has carried out a non
standard mod)
Diffs
The two most common diffs are the 7" and 7.5". This is actually the size of the crown wheel, but fortunately is mirrored by the length of
the top bolt fixing. In addition the 7" unit has an open bolt fixing and the 7.5" has a closed bolt fixing.
There is only one type of oil seal kit quoted, and I am assured the seals fit both the 7" and the 7.5". this is good in that one size fits
all.
Given that the seals are the same it looks like the flat bearing surfaces at the top of the half shaft and just ahead of the splined area are also the
same diameter. This is good as one size fits all - but, splines are different
The two most common upper splines are 26 and 28 splines. They are not interchangeable, and must marry up with the shafts.
Drive shafts
The right hand drive shaft is longer than the left and dimensions are shown here.
http://www.super7thheaven.co.uk/components/sierra_rear_drive_shafts/
Bear in mind it is almost impossible to make measurements on the car as the half shafts float about to accommodate suspension movement.
Even though the left and right shafts are different lengths, all left and all right shafts are the same lengths. In this respect this makes them
interchangeable.
Some shafts are 'skinny' at 24mm, and some are 'fat' 27mm. The thickness of the shafts does not denote anything about spline
numbers etc and the two types are intechangable
[Edited on 15/9/15 by bumpy]
I've entered into the issue this week, going from 3.62 diff to a 3.38 and sods laws states my 3.62 driveshafts are 23 spline and my new 3.38 diff
is 26 spline lol typical.
Think that's the outer hub side are all 28 spline.
Tried to buy some new ones from J and R what a crap company, no help what's so ever. So got some second hands ones of Flebay.
Anyway hope she's back together for the weekend, fingers crossed
Originally posted by DRM Black7
I've entered into the issue this week, going from 3.62 diff to a 3.38 and sods laws states my 3.62 driveshafts are 23 spline and my new 3.38 diff is 26 spline lol typical.
Tried to buy some new ones from J and Rwhat a crap company, no help what's so ever. So got some second hands ones of Flebay.
Anyway hope she's back together for the weekend, fingers crossed![]()
Disagree with you there.
The 2 most common diffs were 6.5" and 7". The 6.5"'s were fitted to most Sierras sold with the 7" ones only being fitted to the less common 2 litres, 2.3 litres and 2.8 litres variants.
The 7.5" diffs were only fitted to the Cosworth models which relative to the all models were a very small percentage sold.
Don't forget that Granada's also used the same diffs but no idea what sizes were used.
I've never seen a Sierra 6.5 inch diff!!!
To correct your above statement two wheel drive Sierra cosworths used the 7.5 inch diff.
4x4 Sierra and escort cosworths used a 7 inch rear diff.
[Edited on 15/9/15 by CosKev3]
What function do those large castellated rings serve where the drive shafts enter, they don't seem to hold the oil seals in place.
Also my spare diff has been stored without drive shafts and hence the innards exposed for some time (before I bought it). What should I use to
flush/clean it out - I am thinking paraffin or petrol.
Originally posted by tims31
Agree with this, my diff came from a 1.8 Sierra Saphire and that is a 7.5" diff.
Also my spare diff has been stored without drive shafts and hence the innards exposed for some time (before I bought it). What should I use to flush/clean it out - I am thinking paraffin or petrol.
Them castellated rings do a very important job to hold the side bearings in place and to set the backlash!
Sorry but you are very wrong.
1.8 hatch and saloons came with either a 6.5" or a 7" diff. Estates were fitted with a 7".
7.5" only came on the Cosworths and according to legend some 2WD V6 models.
Think you need to recheck your facts.
I've decided to change my diff from 3.38 to 3.92 and despite a seemingly fair bit of info out there its a bit of a mine field, so I have decided to capture what I have read and I hope you guys can correct anything that's wrong.
I will restrict the discussion to the push in shafts which in turn means only drum brake cars (unless some clever person has carried out a non standard mod)
So to this.
You could get any 7" diff with a 3.92 ratio and fit the centre with the correct spline size for your shafts from your 3.38. I guessing this is a diesel diff.
Or you can make up some hybrid shafts if you can find the right tripod joints or shafts. This i can't help you much with.
Yes use the stretch cv. They work, warm it first
Bit more progress on the half shafts.
Have cleaned off all the rust and flaky paint for a respray and have peeled back one of the existing gaiters.
First thing I noticed was that the (cold) grease poured out like treacle - I guess it was well past its sell by date
Second thing I noticed was that both the shaft and CV casing are 'grooved' to accept the gaiter. The gaiter, in turn, had similar profile
inside to fit these grooves. (Photos attached)
Is this common for all drive shaft gaiter fitments and would it making fitting the stretchy gaiters a problem as they are universal and almost
certainly will not be sculptured to fit these grooves.
[img]
[/img]
[img]
[/img]
