Evening folks.
Now I have figured out what sort of expansion/header tank I am after for my car's cooling system, (with thanks to everyone here that helped and
offered advice!) I need to find a suitable tank.
So, can anyone recommend a suitable tank? I am after the following:
FWIW I used a Rover 25 expansion tank, mainly because my K series was from a Rover 25 so I figured the hoses should match up!
It's got a top and a bottom hose and a pressure cap, and has marknig on the outside. it is designed to "hang" somehow on the original -
to fit it in my engine bay (after I had fixed other stuff to the scuttle...) I made a bracket to suit from ali.. Pic in my archive called
Volkswagen new caddy expansion tank with level probes fitted..
You'll need the cap to fit obviously, the right connector for the probe and a relay from a mark 2 golf for lighting up a bulb in the dash when
the level drops too low..
All that lot for ~£30 brand new and shiney..
I have all the part numbers if interested..
[/works for a VW van centre in the parts department blog]
[Edited on 23/11/07 by Metal Hippy]
Ive just fitted this ,brought for my R32 but found a use on the Mac#1
(pressed steel bracket now changed for solid alloy one now
it measures approx 60mm x 150mm 4 outlets @ 8mm & comewith tubing & 3 caps (small Jdm type) ,was a pain filling or checking the coolant
without it ,I got it from http://www.driftworks.com/catalog/
on a special offer,wasabout £28 posted if i remember ,give them an email as they dont seem to have any in the shop atm
i would use a toyota mr2 roadster type, its clear and has correct pressure relief cap, an outlet and inlet, its what i will be using, or like said a
vw one is ok.
rob
Good old ebay. I got a spherical VW/Audi one as fitted in the Audi TT for the princely sum of £0.01+ £2.50 p&p.
I used the Rover 220gti old type(>95)Also I think that the Rover diesel218/418 Peugeot engined cars might be the same.
If you look in my photo archive you can see it in "beauty and the beast" picture.
Works ok on my 4age.
[Edited on 26/11/07 by DEAN C.]
Hi the later vectra ones brandnew from the stealer are £9+vat. And come with one or two ( depending on model )8mm returns and the usual 15mm bottom
outlet.
Cheers Matt
[Edited on 28/11/07 by procomp]
