kevin booth
| posted on 5/4/06 at 09:11 PM |
front brake pipe flexies
On full lock flexies are touching the tyres, how do i stop this ?, thanks kev.
[Edited on 5/4/06 by kevin booth]
steve_gus
| posted on 5/4/06 at 09:12 PM |
Either route them slightly differently so that they flex in a different position, tie them to the 'bones in some way, or restrict the amount of
lock by modifying the rack.
atb
steve
[Edited on 5/4/06 by steve_gus]
http://www.locostbuilder.co.uk
Just knock off the 's'!
RazMan
| posted on 5/4/06 at 09:14 PM |
Form a coil or S bend to the end - this should allow you some clearance lock to lock.
Raz
planetester
| posted on 5/4/06 at 09:23 PM |
slacken off the locknut & rigid pipe at the chassis end & put a SLIGHT twist in the flexy, you will know which way to twist it by the
result,when your happy tighten up the locknut & the rigid pipe
tom windmill
| posted on 5/4/06 at 10:12 PM |
Swap the back ones for the front ones thats what we did.
HTH Tom
k33ts
| posted on 5/4/06 at 11:51 PM |
do something like this
tukcustoms.com
DarrenW
| posted on 6/4/06 at 09:25 AM |
My flexis connect higher up on the side panel. I added a twist to them so they kind of self coil up slightly and therefore dont foul on anything.
