New Topic New Reply
Author: Subject: Electric Motor Blower
James
posted on 5/4/04 at 04:27 PM Reply With Quote
Was just wondering if electric motor powered 'chargers exist and if not- why not?
My suspicion is that they may take as long to spin up as a turbo but without the benefit of being powered 'for free' as it were from exhaust gases.
Thoughts?
James
MikeR
posted on 5/4/04 at 04:55 PM Reply With Quote
I think the issue is getting enough force from the motor without drawing huge amounts of current.
Alan B
posted on 5/4/04 at 05:17 PM Reply With Quote
Yep...you would need such a big alternator to supply the current you may as well just drive the blower directly and save the coversion inefficiencies...
blueshift
posted on 5/4/04 at 10:02 PM Reply With Quote
... and the weight of the big alternator and motor (just pulleys)
Mark Allanson
posted on 5/4/04 at 10:21 PM Reply With Quote
I thought an electric blower would be controllable by an ECU, but I suppose that a hydraulic clutch activated by a servo would be just as good if not better
stephen_gusterson
posted on 5/4/04 at 10:45 PM Reply With Quote
you can buy an electrec turbo called a turbozet
http://www.turbozet.com/
supposedly total crap
atb
steve
posted on 6/4/04 at 09:09 AM Reply With Quote
so is an electric turbo better than an electric supercharger!!!!!
i know, there should be no difference.
would an electric turbo still have a turbine in the exhaust? hence would it be an antilag device? and would a leccy super use the motor to help turn the crank too?!
stephen_gusterson
posted on 6/4/04 at 09:17 AM Reply With Quote
effectively the turbozet isnt a turbo, as its not exhaust driven.
It woukld melt as its plastic.
If you think about it, can you see a little lekky motor being able to compress air at a volume of approx 2 litres per 2x crank revs at 6,000 rpm to approx 8 - 15 psi?
I cant.....
atb
steve
GO
posted on 6/4/04 at 09:37 AM Reply With Quote
We had a little thread on this subject before...
thready
stephen_gusterson
posted on 6/4/04 at 12:38 PM Reply With Quote
a whole 1psi!
I wonder if an engine driven fan (the one that would have cooled the rad normally) could be boxed in and used..... it could have a 'waste gate' to divert any flow thats not needed, so its effectively always on, but bled away when not needed.
atb
steve
carcentric
posted on 6/4/04 at 04:45 PM Reply With Quote
An alternative boost source
There was a fellow on the Dodge Dakota forum who was experimenting with providing boost from the output end of a two-cycle leaf blower (if you have such things over there).
If I remember correctly, it was constant speed producing constant pressure rather than variable according to load so it added a high-pitched bagpipe-like drone to the vehicle engine's song.
Don't know if he ever finished it or if it remained in the prototype stage.
M D "Doc" Nugent
http://www.carcentric.com
NS Dev
posted on 7/4/04 at 11:36 PM Reply With Quote
Hmmmm, all this sounds decidedly smelly of something unpleasant!!
A typical supercharger on a typical 2.0 litre engine running at typical peak rpm will typically (like that word) draw about 15bhp from the engine that it is feeding at typical (10 -12psi) boost levels, that's a heck of a big 12v dc motor!!!!
As an interesting aside, a top-fuel dragster at 8000rpm uses approximately 250-300 bhp to drive it's supercharger!! (mind you the engine in making circa 7000bhp so it's not too bad!!)
Mark Allanson
posted on 8/4/04 at 05:39 PM Reply With Quote
Why cannot you use a turbo impellor to drive an alternator - no losses when your lights are on etc
gjn200
posted on 8/4/04 at 05:42 PM Reply With Quote
It would cost to much,£600 ish for a turbo type thing for a couple of bhp.
<- Me!
New Topic New Reply
