Author: Subject: Gear lever adaptor
40inches
posted on 15/11/09 at 06:28 PM Reply With Quote
Gear lever adaptor
A nice cheap GEAR LEVER ADAPTOR just cut the pedal end off,and drill the clevis/rod end mounting hole in the blade.
NTDWM, it's just wkat I did
Shiny Gearlever
Shiny Gearlever
Richard Quinn
posted on 15/11/09 at 06:46 PM Reply With Quote
I used something very similar but mine was adjustable in length so even had holes already drilled along its length
40inches
posted on 15/11/09 at 07:35 PM Reply With Quote
Yea, my first attempt was with something along those lines, but I trimmed it down and it then wasn't long enough for the Klicktronic actuator.
Red gear lever
Red gear lever
will642
posted on 19/11/09 at 07:08 PM Reply With Quote
adaptor
where did you get the crank assembly you are using?
40inches
posted on 20/11/09 at 12:46 PM Reply With Quote
The top crank/lever was from Pathfinder, he used to post on here, but seems to have gone AWOL pity, because he did some quality work, especially on paddle shifts. The pushrod is ZX9R-C.
