FFTS
posted on 30/4/10 at 09:25 AM |
R1 Airbox to fit under bonnet not through it.
Has anyone either sourced or made a R1 ramair box that will fit under the standard bonnet with small bulge.
Would like to take of the foam filter but dont want a monster sticking through a hole.
Photos and advise appreciated.
Chris.
dave107
posted on 30/4/10 at 09:28 AM |
Iain B at MNR has, give them a call.
A1
posted on 30/4/10 at 10:52 AM |
on my mk ive got k&n filters, these fit fine
posted on 30/4/10 at 11:34 AM |
Assuming that there is no problem with your foam filter, why do you want to replace it with an airbox?
If you replace the filter with an airbox, your engine will need re-jetting/re-mapping to suit and could potentially cost a few ££ for little
gain.........
Phil
hobbsy
posted on 30/4/10 at 11:48 AM |
@hellfire - potentially lower intake temps and better ability to get cold air to it with Naca ducts etc.
You could do a cut n shut to reduce the height of it a bit. I don't know what the clearance is like if your case but that's what I'd
need to do to get one under the bonnet of my fury. Also turning it around the other way sometimes helps.
maximill666
posted on 30/4/10 at 01:33 PM |
Iain has a a Pipercross airbox on his VortX, but unfortunately they wont fit under the bonnet on an early VortX as the body is not as tall
GeorgeM
posted on 30/4/10 at 02:01 PM |
amalyos made his own to fit under earlier bodywork, - have a look in his archive.
I'm sure he'll show you at Stoneleigh if you are coming. He will be on the MNR area.
GeorgeM
My conscience is clear - I drive a GREEN car
MNR Racing
essexkitcarclub.com
posted on 30/4/10 at 04:16 PM |
Yep, I understand all that but what I was getting at, is whether these gains are worth the extra cost of re-jetting/re-mapping.
There's also a benefit in noise reduction but again unless it's for a specific purpose, I'd doubt it's worth the extra
cost?
Phil
matt_gsxr
posted on 1/5/10 at 10:16 PM |
I don't know the ins and outs of this. But when I ran on the 9th April at Abingdon. I had an air box and no ducting and megasquirt air temp was
52deg C. With ducting this came down to 21deg C (it was a warm day).
I don't know the exact formula but if it were an "ideal" gas (PV = RT), this would correspond to an air density drop of 10%,
(31/293) which is the same drop in power.
In my case I have a complete bonnet with no ducts and the GSXR airbox fits under the bonnet without adaptation.
This doesn't solve your problem, but I think you are going in the right direction.
Matt
