gml7
posted on 6/6/10 at 09:08 PM |
4age silvertop supercharger
I've got a toyota 20v silvertop in my Striker and a spare/scrap silvertop in the garage that died on me from an oil surge! Short sump, not
enough oil in it, hard corner then a horrible knocking noise! Very annoying and embarrassing!
Anyway! The Striker is now back on the road with a replacement engine.
I'd like to go down the rotrex supercharged route. More power whilst keeping all the good bits about this engine, mainly revs and reliability
(when filled up with oil and fitted with an accusump)!
My plan is to rebuild the spare engine, get the crank re-ground etc. and then switch it into the Striker when it's ready to go. This way I
reckon i can maxi my driving time.
I would appreciate any advice! Things that definately need upgrading or changing, supercharger models, what to do what not to do, places to buy parts
from etc.
[Edited on 6/6/10 by gml7]
blockhead_rich
posted on 6/6/10 at 09:20 PM |
Hi
Good luck with your project. I aim to go down this route when funds allow.
I have a spare full engine gasket set for the Silvertop engine for sale, U2U me if your are interested (I know they are quite hard to get in the
UK).
I have also found a good source for rings and bearings in the US that I can let you have.
I'll be away from tomorrow until late Thurday however.
Rich
bi22le
posted on 6/6/10 at 10:21 PM |
hi gml. Welcome to lcb.
Im also going to go down this route in a couple of years.
There are a number of people that have built or currently own a 4age with a charger.
A guy on here called bimbleuk ( hope you dont mind the name drop justin?!) built my car and also an engine to the spec you want. Unfortunatly my car
doesn't have that engine in it though. He knows alot about there engines and setups with s/c. It would be worth trying to find his blog or
contacting him. If you search raw striker supercharged on youtube thats my car but with the better engine. 270 bhp, that will be fun!
Keep us up to date with the progress.
Please read my ring story:
stevebubs
posted on 7/6/10 at 12:49 AM |
I believe Andy Hampshire on the sylva-chat list has already gone down this route and been running like this for a couple of years....
oldtimer
posted on 7/6/10 at 08:02 AM |
The simple, but not cheap, answer is to fit the Raw Engineering Rotrex supercharger kit which is ready to fit to 4age 20v silvertops.
bimbleuk
posted on 7/6/10 at 09:54 AM |
The simplest option is to buy the OMEX kit and that's almost a complete bolt on solution.
The second is obvously to make you own braketry, plenum and inlet gubbins.
To prep the silvertop engine you can simply fit the 8.9:1 4AGZE pistons and that should be good for 1 bar or around 300BHP. I had mine fly cut to
match the 5 valve pattern and retain the "safe" engine configuration. Others have fitted them but valve piston contact is possible.
Want more power then you need to consider changing the rods and pistons. I know Richard at OMEX has done this to his engine.
The OMEX/RAW kits use the C30-74 Rotrex on the standard engines. However if your serious then the C30-94 is the only one too consider. Looks too big
on paper but not when it's actually used. Plenty of potential though.
Dopdog
posted on 7/6/10 at 11:41 AM |
supercharger
you must be the guy that had the engine off Tim. Give him a call as he has a supercharged 20v in his striker, it made 272bhp on the rollers.![](/images//smilies/cool.gif)
bimbleuk
posted on 7/6/10 at 03:04 PM |
Two other things to consider. The gearbox and clutch.
I was using a BGH E7 heavy duty type 9 which never gave me problems with 195 lbs ft and high RPMs.
Also I had to fit an upgrated clutch to cope. I bought a Helix clutch kit via Fensport. Very nice feel to it and not what what I was expecting from a
paddle friction plate.
Unfortunately these items all start to add up.
BGH E7 = £1200 + VAT
Helix clutch = £400 + VAT
[Edited on 7-6-10 by bimbleuk]
gml7
posted on 7/6/10 at 09:09 PM |
Wow fast responses! Thanks!
Dopdog, I did get the engine off Tim, and it was chatting to him that got me thinking about a s/c!
If i go down the C30 94, does anyone know where to get new 4AGZE pistons or is it a scrap yard job?
When the old engine died the bearing marked the crank. Its not too bad but you can tell that the surface is slightly damaged. Should I re-grind it or
get a new crank?
I think mine could be the heavy duty box, but I'll ask Mel if he can remember. The reciept in the file that the guy who sold it to me just says
BGH gearbox! Is there anyway of telling?
bimbleuk
posted on 8/6/10 at 07:12 AM |
I bought mine from Fensport who just ordered them from Toyota Japan. They get weekly deliveries so no long delays. When I bought mine they were £36
each I can't remember if that was inc VAT or not. They come with wrist pins but not rings. Rings are another £100 but Toyota rings are ususally
chromolly so very high quality.
Unless the tag is still on the box from BGH then you may have to open the box to tell. I don't know what to look for though just there are
uprated bearings in there some where!
