Author: Subject: reverse switch type 9 electrical 2 pin plug
loughlin1
posted on 1/7/12 at 09:56 PM Reply With Quote
hello
would anyone know where i might get the electrical term to fit a 2 prong reverse switch
Staple balls
posted on 2/7/12 at 12:51 AM Reply With Quote
Scrapyard usually.
Failing that I reckon some 5mm or so bullet connectors, or just solder and heatshrink should do the job well enough.
HowardB
posted on 2/7/12 at 07:23 AM Reply With Quote
mine are solder on, and then two short lengths with spade connectors on, that means that the wiring is easy to remove at a remote location.
hth,..
Howard
RoadkillUK
posted on 2/7/12 at 12:24 PM Reply With Quote
hth,..
I've done the same as above, makes for easy access should you need it.
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
jamesbond007ltk
posted on 2/7/12 at 02:11 PM Reply With Quote
Originally posted by Staple balls
Scrapyard usually.
If you do go down the scrappy route I am pretty sure the same connector was used on same early MK3 escorts (the ones with the squarer lights). HTink that is what mine came off.
Probably used on other fords gearboxes around that time too, if there are any about still!!
Rich
[Edited on 2/7/12 by jamesbond007ltk]
Furyous
posted on 2/7/12 at 03:27 PM Reply With Quote
Mine had a couple of female bullet connectors on it.
loughlin1
posted on 3/7/12 at 05:55 PM Reply With Quote
all sorted chaps thanks to everybody
