Antas
posted on 25/9/12 at 01:37 PM |
Diff from Scorpio
I have been offered a diff from a Scorpio.
It has severel marks:
-FINI 1009416
-93BG-4200-AB
What type of diff is it and what is the diff ratio?
Anders
Luleå, Sweden
Chippy
posted on 25/9/12 at 02:17 PM |
This may be of assistance. HTH Ray
Locost link
Antas
posted on 25/9/12 at 02:44 PM |
Thank you, but I can not find my codes in that link.
snapper
posted on 25/9/12 at 04:01 PM |
Most Scorpios ran an open diff as traction control was fitted
To test turn input shaft if both outputs move the same way its LSD
There is usually a metal tab off the top left cover bolt this has a code with ratio in
Last resort take cover off it written on the down wheel
I eat to survive
I drink to forget
Antas
posted on 25/9/12 at 04:09 PM |
The diff is still mounted on the car and the car is standing on the ground without wheels.
Before I decide to turn the car over and take away the diff I would like to know what the codes mean.
If the diff ratio isn´t around 3,62 I think I will leave it.
I can´t see the metal tab under the car for the moment.
mcerd1
posted on 25/9/12 at 04:11 PM |
is this any help?
http://www.super7thheaven.co.uk/Sierra_Rear_Differential
or what is the 'Axle Code' on the cars VIN plate ?
it should be easy enough to work out even if you can't find the codes - if you can post some pic's of the diff it would make it easier for
us to help you
the ratio will depend on the engine, but my guess is its most likley a 7.5" open diff with bolt-on driveshafts.
[Edited on 25/9/2012 by mcerd1]
loggyboy
posted on 25/9/12 at 04:19 PM |
Its likely to be 7.5 inch. Most kits use the siera 7inch. Might be why the codes dont reveal anything.
Mistral Motorsport
jollygreengiant
posted on 25/9/12 at 05:12 PM |
IF you do get it, take the Drive-shafts AND hubs as well. The wheel Flanges will be 4 bolt with the same PCD as sierra, ALSO I found that the bolts
that hold the CV joints/flanges together were a slightly larger diameter than the normal Sierra/Granada items. The one that I got off of a Scorpio
(last production model) was a 3.38 diff.
[Edited on 25/9/12 by jollygreengiant]
Rob Allison
posted on 10/10/12 at 12:59 AM |
Scorpio driveshafts are longer than sierra ones and if its a 24V the cv joints are 108mm not the normal 100mm as a 7" sierra diff
