Author: Subject: my bad!
Nightkid
posted on 26/3/05 at 12:37 AM Reply With Quote
my bad!
Hey all
need some quick advice. I was stripping my escort mk2 today and i managed to shear one of the bolt that holds the alternator to the chassis. DOH! the main thread is still in. i thought about trying to weld the end of the bolt back on and hopefully the bolt will hold. Plus the heat might help loosen the rust. any ideas!? Thanks guys!
stevebubs
posted on 26/3/05 at 02:34 AM Reply With Quote
If there's enough of the bolt still sticking out, you may be able to plug weld a nut on there.
violentblue
posted on 26/3/05 at 07:59 AM Reply With Quote
if the bolt is broken off flush I'd reccomend an "easy out" if you have such a thing on that side of the pond.
you basically drill a specific size hole in the bolt and drive a tappered square bit with teeth, into it, then turn out with a wrench, helps to heat it a bit as well.
a few pics of my other projects
Nightkid
posted on 27/3/05 at 02:29 PM Reply With Quote
cheers guys i give that a try
Stu16v
posted on 27/3/05 at 08:27 PM Reply With Quote
Do not use 'easyouts'. If it was tight enough to shear the bolt, an easyout doesn't stand a chance - all you will be left with is a lump of tool steel to try and drill out to get the remains of the bolt and the easyout from it's present location...
Things of evil, them things...
Stu16v
posted on 27/3/05 at 08:29 PM Reply With Quote
Nightkid, I presume it's a typo?
Alternator bolted to the chassis?
