Author: Subject: Shockers upside down?
emsfactory
posted on 9/12/05 at 01:06 PM Reply With Quote
How do you know if your shockers are upside down?
I have GAZ shocks at the front with the adjusters at the top.
Spax gas ones in the rear with the adjusters at the top.
Right or wrong?
Also, what difference does it make?
Triton
posted on 9/12/05 at 01:14 PM Reply With Quote
Unless you have special dampers the main body should be at the bottom
www.tritonraceseats.com
www.hairyhedgehog.com
Viper
posted on 9/12/05 at 01:17 PM Reply With Quote
shocks can have adjusters at the top or the bottom, the spring platform is normaly at the bottom, and if you run a shock upside down, thats not designed to, you can end up aerating (sp?) the oil...not a good thing to do
emsfactory
posted on 9/12/05 at 01:46 PM Reply With Quote
Will having them upside down change the handling?
Viper
posted on 9/12/05 at 01:55 PM Reply With Quote
oh yes and your fronts are upside down.
emsfactory
posted on 9/12/05 at 02:32 PM Reply With Quote
Cheers. I'll swap them over and see what happens.
