Arthur T
posted on 24/1/07 at 09:37 PM |
Toyota 4AGE 20V - V - Zetec
why do people go for a Zetec when the 4AGE gives more power & weights less?
can a 4AGE be fitted to a type 9 gearbox?
MattCraneCustoms
posted on 24/1/07 at 09:53 PM |
Can a 4AGE fit a type 9 gearbox?
My guess is that that is your answer right there. Zetec bolts straight on. I don't know if availability of parts could be an issue?
Regards
Matt
flak monkey
posted on 24/1/07 at 09:55 PM |
4 age can be bolted to a type 9. Needs a different bellhousing though. Raw Engineering do all the stuff if i remember rightly:
http://www.rawengineering.co.uk/
Sera
http://www.motosera.com
TimC
posted on 24/1/07 at 09:59 PM |
The zetec is 2-a-penny wheras 4age is rarer and therefore more expensive.
Great motor though. Looks the part too!
DEAN C.
posted on 24/1/07 at 10:13 PM |
There are plenty of 16 valve 4ages about, and quite a few imported 20 valves.
parts are very reasonable and available.
Most older toyota parts become discounted after a certain age and you can get copy bits ie,water pumps,belt tensioners etc from people like
Fensport.
Dont think the Zetec screams like the toyota though at 8000rpm!!!!!
If you are looking for 150 bhp plus the zetec may be better,but have you seen how big and deep a zetec is?
The toyota is tiny and quite light,and is basically a rip off of the old BDA lump.
[Edited on 24/1/07 by DEAN C.]
Once I've finished a project why do I start another?
sept
posted on 24/1/07 at 11:38 PM |
20v is an good high reving engine. Zetec has 30% more weight but is an lot cheaper in standard form. An 2ov comes standard with trottle body,s so if
you do an fair compersation than you need them also on an zetec. and thats an 700 pond extra on the zetec.
correct raw is selling them an they have an rearwheel drive conversion.
Mischa
sept is seven in french
Mischa
ghuncha
posted on 25/1/07 at 01:56 AM |
well from where i am (asia) 20v is a lot cheaper and more abundant than the ztec...... so i think its good news for me that 20v is
lighter...hehe..
btw can anyone give me the the weight comparison of the two motors...thanks
[Edited on 25/1/07 by ghuncha]
bimbleuk
posted on 25/1/07 at 05:14 AM |
I can tell you my 20V 4AGE with inlet manifold plus ITBs, block, head, sump, flywheel (ally) and clutch but minus the ancilliaries was 90kg. Add about
50 kg for the type 9 gearbox, bell housing and alternator and starter.
bimbleuk
posted on 25/1/07 at 05:18 AM |
Oh and that certain book probably has a lot to do with peoples choice of engine as a lot of people have it in their head they should be using a Ford
engine.
As mentioned above the bell housing and clutch conversion kit probably puts people off as its around £330 in addition to the engine and GBX.
ghuncha
posted on 25/1/07 at 05:57 AM |
well 90 kg thats good... is it silvertop or blacktop, i have heard that blacktop is a bit lighter......
i wont be using type9 tranny, have my eyes on toyota t50 tranny... it weighs around 26 kgs...
@bimbleuk
what is your car 0~100kph time and top speed you have managed...
thanks
bimbleuk
posted on 25/1/07 at 10:56 AM |
Blacktop and it would be maybe a kilo or so lighter but not much. My flywheel is about 3 kg lighter than the blacktop flywheel (which is the lightest
Toyota did).
thomas4age
posted on 31/1/07 at 07:48 AM |
or fit a toyota T50 gearbox, all alloy 5 speed super slick shift thingy that only wieghs 28kilo'.
some people state that i will blow up under 20v power but it doesn't !period!
goes like mad anywhere in the rev range and brings power in a whole different manner than a zetec does. it's very much alive whereas a well
set-up 1800zetec on webers (without any aditional stuff like cams etc) feels more plumb,
also returns more miles to the gallon btw
grtz Thomas
If Lucas made guns, Wars wouldn't start either.
