thegasmen
| posted on 2/12/07 at 04:18 PM |
oil lines to acusump
Hi I ALL
I am just trial fitting my accusump into my dax Is It possible to pipe up the oil line from the accusump in 15mm copper pipe because there is a bit
of a distance between engine and accusump has anyone done this before.
regards Mick
Aico
| posted on 2/12/07 at 06:01 PM |
I haven't done this before sorry
Jon Ison
| posted on 2/12/07 at 06:12 PM |
Cant see why not, you will have a larger capacity accusump too as a bonus ?
Where are you picking the oil up from the engine ?
thegasmen
| posted on 2/12/07 at 06:55 PM |
accusump
I was going to pipe the accusump into were the oil pressure switch is fitted
Jon Ison
| posted on 2/12/07 at 07:21 PM |
Yup, that's the place on the Bird, that's why I asked, if you break into a oil cooler line its much less effective, (totally ineffective)
the oil cooler runs at reduced pressure and returns oil to the sump, not the oil galleries, not trying to teach you how to suck eggs, just making sure
you protect your engine.
thegasmen
| posted on 2/12/07 at 09:05 PM |
accusump
Thanks jon
any help is appreciated i just need to squeeze it all into the car some how.
cheers mick
INDY BIRD
| posted on 8/12/07 at 10:08 PM |
I fitted mine to the oil gallery spare on the front of the engine,
Look at the blue pipe follow it it gives indication where to fit it.
Hope this helps,
