blah blah
how long before some smart arse replies?
preffered the boobies
Wow under a minute
waste of bandwidth...
Seriously tho... has anyone noticed anything odd with the site? I'm tweaking, and it's all going too well, which makes me suspicious!!
Chris
Seems good, haven't noticed any speed issue or dodgy pages being parsed.
What bit you playing with and we can keep a special eye on it?
Rich
I noticed the smilies on the right of the new post bit turned to just characters about 10mins ago, but now all fine again.
going into my subscriptions still crashes my browser, but that only seems to be me
I'm messing around with URLs - ie the address that appears in your browser for each page you look at.
Chris
Is it me or has page two of for sale gone!!
Thanks! Hadn't spotted that. Fixed now (well, botched to make it work anyway!).
Chris
And there was me having a panic.....
Randomly comes up 'file not found' when clicking through forums now. But if you go back and click again its ok....?
Was completely broken with "file not found" errors on every forum first thing this morning, but seems to be working 100% now.
(bar the problem I've had for a while with attached images in chrome - they display and then disappear [fine if opened in their own tab]) but I
think that's just me on the bleeding edge development version on linux) Should raise a defect on chrome really.
Just realised it was my link direct to the forum section that was causing my breakages this morning.
I'm still getting the "file not found" error on my work machine, but it's ok on my phone's browser - which is where I'm
typing this.
Chris, FYI, my work machine is running Windows 7, and all internet access is via Denmark (head office).
Originally posted by David Jenkins
I'm still getting the "file not found" error on my work machine, but it's ok on my phone's browser - which is where I'm typing this.
Haven't noticed any problems whatsoever
Hmm - that seems to work - but it's a pain going that way on my phone browser as the link is so small, and hard to click on.
N.B. Shortly after saying that it worked on my phone, it gave me the 'file not found' message. Doesn't happen so often though.
Originally posted by iank
Are you using a link directly to the forum on the work machine. That was my problem. If you go in via the link on the front page then hopefully it should be fine. (then re link the bookmark/favourite obviously)
The file not found thing is easy enough to fix.
Your bookmark is to http://www.locostbuilders.co.uk/forum.php
Edit it so it goes to http://www.locostbuilders.co.uk/forum
and it'll be fine.
Cooo - that works!
If you hit refresh when on the /forum page it refreshes to the /forum.php page then no links work again
the catch up button is borked, catches you up, but goes back to forum.php after
I'm getting fed up with this bug now...
Still broken on both refresh and catchup
Both take you back to forum.php and then no links work
I don't have the refresh bug.
Try Crtl + F5 to clear cache?
Nope still broke on all 3 pcs I use and cleared cache/history on them all and a mix of FF and IE all the same problem.
