Every time I hit the Post New Topic button, I just get the same page back again.
It works in Mozilla.
Thanks,
Tim
There's an easy solution to that problem!
Chris
i like your approach chris
Easy - Have you seen how long Mozilla takes to start up on anything other than a supercomputer!?
Ok, I'll use Mozilla.
Thanks,
Tim
Chick
Much as I like to support alternatives to M$, IE is very good and used by 99.something% of visitors to this site. Being able to run IE is the single
biggest reason why I'm not running a Linux desktop. I have to make sure any web work I do works in IE and therefore I need to have it running
without any faffing about.
Chris
Have you tried wine? Its seems to run IE quite well!
I'm not really a linux nutter, I used to use windows, and don't have any religous beliefs either way. IE is pretty cool as a browser. I just
use linux now as it is cheaper, if you don't want to just pirate windows.
Anyhow, I guess I've wasted enough of everyones time already.
Thanks,
Tim
I thought only IE4 ran under WINE?
Chris
would mozilla firefox not be the better option?
lighter than full mozilla, and will work
Well with a fresh SuSE 9.1 install, konqueror is
now working!
As for wine, I believe considerable success has
been had with IE6.0 SP1. See
http://appdb.winehq.org/appview.php?appId=25;PHPSESSID=5c26e268c985781222efd0cd988c58e8
Tim
