I know it's probably not used that often, but everytime I have had to use the [ code ] block I have to fight it.
1) It's double spaced by default, this is ugly and makes things take too much space.
2) text within the code block is supposed to remain unformatted by the forum, but it still insists on converting bits of text into smileys
code:
There should be no smiley on the end of this line![]()
depends if you want smileys on or not, but use the text box to disable them on that particular post. you can also diasable BB code too.
:):(:D;):cool::mad::o:P
[img]http://locostbuilders.co.uk/upload/pickup.jpg[/img]
etc etc
code:
Never see this before, is much code posted on this forum?
Originally posted by sprouts-car
code:
I have a program that you can define using numbers diffferent levels so it produces an ASCII art that you stare and get 3D image.
